Water Pump leaking from small hole in front cover?
Old May 6, 2014 | 08:01 AM
ralphobell's Avatar
Yes the link I posted is for an Airtex, OEM Replacement with Brass Impeller.
Old May 7, 2014 | 03:37 PM
LADEROUTE's Avatar
Thanks for the input everyone.
I found the thread Disco Mike had commented on regarding a "heavy duty" water pump with brass impeller from BP Utah and it is the same Airtex model Atlantic British offers.
Atlantic British matched the $139.00 and I should have the part this Friday.
For installation Is there any need to use high temp silicon gasket materials or is the supplied gasket sufficient?
Old May 7, 2014 | 07:12 PM
OffroadFrance's Avatar
Unfortunately the pump defo shot. The hole is a 'tell tale' hole exactly to show a defective leaking water pump.
Old May 8, 2014 | 06:40 AM
drowssap's Avatar
i always back the gasket up with a thin layer of black RTV, but that's just me
Old May 9, 2014 | 02:19 AM
montana968's Avatar
i just used the supplied gasket. still works great.
Old May 9, 2014 | 04:16 PM
Dane!'s Avatar
A small hole? You mean the weep hole? or am I mistaken?
How much was it leaking? The weep hole on all water pumps are supposed to leak a little, in certain conditions. Its to adjust for changes in atmospheric pressure. If its leaking a lot, change it.
EDIT: Didn't see you said there was a puddle.... opps. But yeah, its coming out of the weep hole.
Old May 9, 2014 | 07:35 PM
ralphobell's Avatar
He had puddles under his Rover. The WP is toast.
Old May 9, 2014 | 08:05 PM
Dane!'s Avatar
Yeah definitely. lol. I have the aftermarket one, its a little bigger.
Old May 16, 2014 | 12:02 AM
LADEROUTE's Avatar
Swapped the old pump for the Airtex from Atlantic British and all is good.
Got a little frustrating trying to knock the fan loose with the 36" fan wrench as the belts kept slipping. I had to slide in a large flat head between the bolts on the water pump pulley to stop it from turning and then knocking the fan wrench - it finally came loose.
Old May 16, 2014 | 12:17 AM
Dane!'s Avatar
Very nice, glad it worked out!
TRIARII
Jan 22, 2014 08:21 AM
NickDII
Jan 23, 2012 12:00 PM
Helper
Dec 14, 2010 08:18 PM
audiS4S6
May 6, 2010 12:14 PM
panther9
Aug 7, 2008 08:41 AM
