Way to cool the intake temps?
Old Mar 28, 2012 | 08:22 AM
grandkodiak's Avatar
only aftermarket option is a snorkel kit, or fab up your own. you could also install some heat barriers, ie.wrap your exhuast headers, ir reflective insulation on the airbox tube, bypass the throttlebody coolant lines, remove the airbox and put a hiflow cone filter one and box it in so it pulls air from the old drain port hole at the wheel well... just make sure you fab up a blocker so the wheel doesnt chuck rocks/water etc up at the hole if its exposed... i cant remember if its infront of or behind the inner fender wheel well piece.
Old Mar 28, 2012 | 02:13 PM
4x4coots's Avatar
7th Gear
Something like this, maybe.
Gold Heat Reflecting Film self adhesive - Full-Race.com
Old Mar 28, 2012 | 04:20 PM
ATLDisco's Avatar
Couple options:
1) Cheap NOS kit - use smallest jet, 25hp or so - will drop intake temps 30-45 degrees.
2) Install a piece of copper line coiled up in your airbox, and plumb a Co2 tank to it - shot of that will drop intake temps about 50-100F in short bursts.
3) Snorkel - takes no maintenance.
Stay away from cold air intakes - your MAF will become angry the first time it gets wet from them, and it WILL happen.
Old Mar 28, 2012 | 07:07 PM
ebg18t's Avatar
Maybe I will have to look into a snorkel, even know I really don't want one.
Old Mar 28, 2012 | 08:19 PM
ralphobell's Avatar
You could do the snorkel mod, but replace the snorkel stack with a vent or side scoop.
grandkodiak
Jun 22, 2014 03:37 PM
caymandrew
Aug 22, 2013 08:42 PM
Joseph David
Mar 14, 2011 04:04 AM
drdabbles
Aug 17, 2010 07:37 PM
gsxrgessler
Jan 26, 2008 08:34 PM
