Weird Noise Around Rear Wheel
Old Apr 20, 2013 | 08:38 PM
2fasttc's Avatar
Default Weird Noise Around Rear Wheel
Hey Guys,
I have a weird noise coming from/around (i believe) the passenger rear wheel.
Bear with me but it sounds like the noise from a spring mattress, like when your bumping and grinding (sorry kids). I can only hear it at low speeds What should I look for/replace? I want to mention that my rear diff is leaking fluid and it has been for a while but i will be taking care of that real soon but can this be related?
PS. I have a 2001 Disco
Old Apr 20, 2013 | 09:16 PM
Jack up wheel and turn it. Wheel bearings not cheap in a D2. If you have low diff fluid and keep running it you will have even larger repair costs. Have you been keeping the leaking diff topped up?
Old Apr 20, 2013 | 09:32 PM
Alan Phillips's Avatar
Is it only when you go over a bump? It could just be the springs making noise. Stand on the bumper and try bouncing the car, see if you can replicate the noise.
Also, Check your lug nuts.
EDIT: If it's the springs making noise, don't worry about it, it's what they do...
Old Apr 20, 2013 | 09:58 PM
2fasttc's Avatar
Good Idea S.Buzz I'll try that. No, I havent been keeping it topped off, feel free to scold me. You've managed to put the fear in me, so I will take care of it ASAP.
Alan, Im 99% positive its not the springs but will check anyway cause you never know and the lugs too.
bcolins
Nov 1, 2012 08:29 PM
4.6HSE
Oct 19, 2010 11:08 AM
yarddawg
Jun 14, 2009 04:50 PM
eelliott
Apr 22, 2009 12:46 AM
surf9ska
Feb 14, 2006 03:52 PM
