Weird whistling noise
Old Apr 25, 2015 | 04:58 PM
Drubie22's Avatar
Default Weird whistling noise
Hey all. I am not mechanically inclined but have enjoyed working on my 2003 Disco. Anyway, for some time now the engine has this weird whistle that almost sounds like a pulley needs to be greased or something. It increases in volume when the gas is punched and is barely audible at idle.
Is this likely something major or a minor nuisance that I can fix?
Sorry, I know the description is vague. It's hard to explain. Sometimes it's barely there at all and not noticeable. Any help is greatly appreciated.
Thanks!
Old Apr 25, 2015 | 05:18 PM
Celto 4's Avatar
hi there my belt tensioner made a slight high pitched noise as it was going how many miles? Quest auto parts had one oem for a good price by the way
Old Apr 25, 2015 | 06:06 PM
OffroadFrance's Avatar
Could be a leaky exhaust manifold gasket or even the intake manifold leaking. My TD5 suffered a warped exhaust manifold, a common problem, which started with a whisle for some months and after a few months got far louder until a pal who owns a garage checked it out and discovered the problem.
Old May 10, 2015 | 06:05 AM
Frank Clouston's Avatar
Yep Just had that same issue it was a turbo whitle,machined the manifold new gasket, noise is gone away.
Cheers
Old May 11, 2015 | 06:10 AM
Joe Btfsplik's Avatar
To all Td5 owners; replace the studs on the exhaust manifold as well! Preferably with bigger ones that won't shear off. Those manifolds warp over time and bust the studs off, contributing to the problem you all describe.
To the OP; does the noise continue after the engine is shut off? On the assumption you have a diesel, it could be the centrifugal oil filter. They spin at around 15,000 rpm and spin down after the car is off. When they wear they can make a strange noise, too.
Old May 12, 2015 | 10:21 AM
Drubie22's Avatar
No it is not a diesel. And the noise disappears once the engine is shut off. It is a spinning whistling sound if that makes sense that intensifies as the gas pedal is depressed. It's almost non-existent at idle.
Old May 12, 2015 | 04:38 PM
To all Td5 owners; replace the studs on the exhaust manifold as well! Preferably with bigger ones that won't shear off. Those manifolds warp over time and bust the studs off, contributing to the problem you all describe...................................
I'll second that, warps manifold and tears the studs out or shears them off. Worth fitting larger dia heavier studs. Never fit a new manifold as it will also warp sooner or later so get the old manifold machined flat which is also far cheaper and will never warp again ................. (famous last words).
Old May 15, 2015 | 03:51 PM
volksrods's Avatar
5th Gear
Not sure if you have checked or not, I had the same whistling noise only when driving. It turned out to be a bad ujoint on my front driveline that had come apart. Good thing I had an extra driveline!
gkubina
LR2
Jul 17, 2011 04:04 PM
kpl1228
Nov 8, 2010 02:04 PM
mrjlyr
Jan 16, 2010 04:00 PM
inganina
Sep 2, 2009 02:54 PM
inganina
Jul 22, 2009 05:33 PM
