What is the best combination for suspension lift?
Old Sep 7, 2009 | 09:12 AM
Originally Posted by 00&04 Disco
I have owned a 2000 for six years now and done some off roading so I know its limitations and I know how to drive it, I just got a 2004 that I want to make my off roading vehical even though I have my 2000 that I drive everyday. I would just like to know what your suggestions are for suspension and tire sizes so I do not have to do trial and error with thousands of dollars of suspension and tire combinations.
You mentioned your 2000's limitations off road, have you ever engaged it's CDL for that extra traction?
As for suspension, go to Lucky 8 and click on their Old Man Emu logo, you'll find the best prices on their OME medium duty kit for right at $600 plus giving you the coils and shocks needed for a small lift, 1.5"s, great ride and handling. Now you'll still need a new steering stabilizer but that's it.
For tires, either 245/75/16's or 265/75/16's, just remember, the bigger you go the more mileage and power you'll loose.
By the way, are you wanting to install the kit, yourself, and save around $400 in labor, if so ask, someone here and sure help you.
Any other questions, get back to me.
Old Sep 7, 2009 | 02:23 PM
00&04 Disco's Avatar
Mike,
Thanks for the info, I will be installing it myself and I have done coils before. What is the reason that a new steering stabalizer needs to installed?
Old Sep 7, 2009 | 02:49 PM
lipadj46's Avatar
If your old one is bad. I swapped mine when I did my suspension, the original one actually did not seem too bad but figured I would replace it while I was doing the suspension.
Old Sep 7, 2009 | 02:57 PM
lipadj46,
I have the stock 15" wheels that I am thinking about powder coating and putting new bigger tires on. I looked at the lucky 8 web site and since they are the same price would would you suggest the 2" or the 3"?
Old Sep 7, 2009 | 03:06 PM
Torancis_LR's Avatar
lipadj46,
Go for the 2" lift. The 3" requires you to do drivetrain modifications.
Old Sep 7, 2009 | 03:57 PM
lipadj46's Avatar
2" lift is more like 1.5" over stock but it will likely be more for you because your stock springs are a bit beat from age. I chose the 2" kit as I did not want to have to redo my brake lines.
Old Sep 7, 2009 | 04:25 PM
That is what I thought, I do not want to have to change brake lines and drive lines, I just want to raise it a bit and put different tires on it to give it a bit more clearance. Thanks guys!
Old Sep 7, 2009 | 04:50 PM
oysterhead's Avatar
with 3" you still don't have to mod the brake lines.
Old Sep 18, 2009 | 11:41 PM
Default Oyster
Originally Posted by oysterhead
Old Man Emu 2" lift (springs and shocks)
Medium if you don't plan to install bumpers, etc.
HD if you do
Why do you suggest the medium if I am not going to get bumpers right away? I would think the HD would be better for clearance without having a bumper and having bigger tires. Please explain the reasoning. Thank you!
swfqk6
Jan 31, 2014 10:22 AM
daigsdomain
Jun 19, 2013 12:16 PM
PFS
Jan 17, 2011 10:05 PM
95Discovery
Jul 9, 2007 06:44 PM
95Discovery
Jun 20, 2006 02:56 PM
