what is that between rear propeller shaft and transfer case?
Good old bad (_!_) ebrake that locks all 4 wheels! Remove pin from ebrake handle, then you can pull the cable (wrapped in silver heat wrap) out of the cabin, then remove the rear drive shaft, then remove the screw holding the drum on with a manual impact driver, then remove the 4 bolts holding it to the transfer case.
threedeer (12-05-2017)
Originally Posted by threedeer
I've high lighted it here. It has some kinda tube coming from it, maybe a vent tube. I'm wanting to know how to remove it.
Thanks!
Thanks!
mcgyver210
01-30-2011 09:03 PM
jenniemcl
01-15-2011 07:10 AM
