what is that between rear propeller shaft and transfer case?
Old Dec 4, 2017 | 02:47 PM
threedeer's Avatar
Default what is that between rear propeller shaft and transfer case?
I've high lighted it here. It has some kinda tube coming from it, maybe a vent tube. I'm wanting to know how to remove it.
Thanks!
Attached Thumbnails what is that between rear propeller shaft and transfer case?-what-.jpg
Old Dec 4, 2017 | 02:50 PM
Friday Night Disco's Avatar
Parking brake
lake_bueller's Avatar
It's the e-brake
Old Dec 4, 2017 | 03:32 PM
Best4x4's Avatar
Good old bad (_!_) ebrake that locks all 4 wheels! Remove pin from ebrake handle, then you can pull the cable (wrapped in silver heat wrap) out of the cabin, then remove the rear drive shaft, then remove the screw holding the drum on with a manual impact driver, then remove the 4 bolts holding it to the transfer case.
Old Dec 4, 2017 | 05:29 PM
mln01's Avatar
Thanks!
Why would you want to remove it, especially when you didn't even know what it is?
Old Dec 5, 2017 | 06:46 AM
mollusc's Avatar
Won't it only lock the rear wheels unless the transfer case is also locked? It's my understanding that the front and rear axles can rotate independently when the CDL is open.
Old Dec 5, 2017 | 07:51 AM
Alex_M's Avatar
That is correct. Lots of fun for drifting around in the snow if you pull the ABS relay.
Old Dec 5, 2017 | 08:05 AM
threedeer's Avatar
e-break!! That is just wild. Thanks Friday Night Disco, lake_bueller and Best4x4!!
Old Dec 5, 2017 | 08:30 AM
Best4x4's Avatar
Yeah I'm thinking of it with CDL locked.
Old Dec 6, 2017 | 04:01 AM
number9's Avatar
Originally Posted by mollusc
Won't it only lock the rear wheels unless......
Just to clarify it only locks the rear x-box output. Rear wheels don't turn because the shaft is installed. When CDL engaged the front x-box output would also be locked by the drum brake.
johnkbl
Sep 6, 2011 05:05 AM
grandkodiak
Mar 3, 2011 10:02 PM
mcgyver210
Jan 30, 2011 09:03 PM
jenniemcl
Jan 15, 2011 07:10 AM
imike1007
Jul 20, 2010 06:44 PM
