What is this called?!?!
Old Feb 5, 2018 | 08:58 PM
JettsRover's Avatar
Default What is this called?!?!
Just got my SECOND replacement/remanufactured Steering Gearbox via UPS. (the first one was faulty) As you can see in the pictures below, it was damaged in transit. The steel tube that runs across the top of the unit was bent/pinched to the point that I'm concerned flow will be restricted.
So ... I want to only replace the tubing, but I cannot figure out what it is called. Further, I cannot seem to find just that part without purchasing another entire gearbox.
So ... help me out, please. What's it called? And ... what do you suggest for getting just that part?
Old Feb 5, 2018 | 09:02 PM
I bet if you pull the line you could just get a matching piece of straight line down at your local autoparts store with the right fittings and bend it to match
Old Feb 5, 2018 | 09:21 PM
JettsRover's Avatar
From the schematics I've looked at, it appears that tube has fittings formed/welded onto the ends. But I'll pull it to make sure.
Old Feb 5, 2018 | 09:32 PM
annette's Avatar
here you go
Lrcat
Old Feb 5, 2018 | 09:57 PM
JettsRover's Avatar
Thank you, Annette. Now I just need to find one (or, one where I'm not paying in rubels)
Old Feb 5, 2018 | 09:58 PM
Alex_M's Avatar
Should just be flared. A regular ole brake line flare tool should do the job, along with some brake line in the same size as ArmyRover suggested.
Old Feb 5, 2018 | 10:16 PM
JettsRover's Avatar
I can still blow air through it, so its not completely pinched-off. However, with up to 1500 lb/in going through there, I'd rather the pipe was round.
Old Feb 5, 2018 | 10:23 PM
Alex_M's Avatar
Another option; you can also take that line into a hydraulic shop and they should be able to make up another line for you.
Old Feb 6, 2018 | 12:23 AM
OverRover's Avatar
+1, that’s the way to go. It would only take about 10 minutes to make that line. There’s just nothing special about those flares, and they will reuse the tube nuts.
Danny Lee 97 Disco
Apr 15, 2010 07:20 PM
sk_adams
Mar 20, 2010 06:07 PM
JBEGIN
Jun 30, 2009 09:10 PM
aublec22
Jun 10, 2009 06:27 PM
OxyCoRover
Feb 13, 2008 04:31 PM
