Bcu repair
Bcu repair
Aside from Turner in Europe, is there anyone in the US that does BCU repairs? Hopefully in the North East, or do we think a computer repair shop could do it?
I pulled it apart and there are no obvious broken solder joints, rust or burning.
still skeptical that the bcu is the issue, with having swapped it out with the same symptoms. But i do have reduced voltage out of the bcu.
I have I get almost 12v for the drivers side output and the passenger side gets less than 1v. I found a local computer repair shop that is willing to take a look at the board, and if he can find the failed part, will fix it pretty reasonably.
The drivers side being, pins 1 and 4, passenger side, 2 and 6.
I am certainly open to any other ideas. I think I have exhausted every other failure point, the switch, motor, fuses, relays.
I got it back and fixed!!! It turned out it was the broken resistor near the plug. The white piece. Cheap fix.
The place that diagnosed the BCU if anyone needs it done is
609-333-2003
rurianassets21@gmail.com
3371 Brunswick Pike
Trenton, NJ, 08648.
Glad my saga is over with.
609-333-2003
3371 Brunswick Pike
Trenton, NJ, 08648.
How does that explain having the same problem with a different BCU? Maybe the truck is frying the resistors? Not sure if broken resistor meant physically or electronically. Ask him to look at the second BCU, if it has the same problem then something in the truck is likely causing it. Whatever that could be.
Interesting. I agree that it does not make sense. The resistor was cracked, chipped. I do not why I assumed it did not matter, I knew it was broken all along. I did fry a bunch of fuses, 3 and 33. And the glove box light does not work, which i believe is connected somewhere along those lines.
At this point, I am not looking a gift horse in the mouth. After the dash lights fixed themselves after taking it all apart, I think I am going to let it be until something else breaks.
Fingers crossed.
Fingers crossed.
