Old Dec 9, 2013 | 02:35 PM
  #1061
mwelton's Avatar
West System epoxied my peeling dash edge back into place.
Old Dec 10, 2013 | 06:43 AM
  #1062
drowssap's Avatar
pulled the intake to replace coils, wire, plugs & 02 sensors pretty straight forward
Old Dec 10, 2013 | 11:19 PM
  #1063
Street Wolf's Avatar
Removed the belt driven cooling fan and replaced it with electric fans.
Old Dec 11, 2013 | 12:15 AM
  #1064
Madlands's Avatar
What fans did you go with and did you use a thermo switch to control them?
Been thinking of doing the same down the road so I'm really interested in the details.
Old Dec 11, 2013 | 02:03 AM
  #1065
SD4x4's Avatar
5th Gear
Installed a 300 watt led light bar
Old Dec 11, 2013 | 11:49 AM
  #1066
Yep, I have it hooked to a coolant temperature switch in like on the radiator hose. Also the fan is from a 1999 Impala Police package. Relatively the same as any dual fan setup from any 3800 powered car, but heavier duty for police use. Perfect fit for the Disco too.
Police package Impalas can be hit or miss though. Any "W-body" care around that year range will have relatively the same fans however. Grand Prix, Monte Carlo, regular Impala, Buick Regal/Century, etc...
Old Dec 19, 2013 | 01:49 PM
  #1067
Daedrix's Avatar
Banned
Replaced all exhaust gaskets/studes, o2 sensors, and valve cover gaskets.
Old Dec 19, 2013 | 07:40 PM
  #1068
CBRacerX's Avatar
Installed used cup holders and a new style brake light switch. Also ordered parts for an oil pressure gauge and researched a front driveshaft replacement.
Old Dec 21, 2013 | 03:56 PM
  #1069
acamato's Avatar
I created more work for myself... Not happy.
I decided since it was over 50 degrees today, I would replace my power steering return hose. I pulled the ac/ace/ps bracket to get to the clamp on the bottom of the ps pump. The bracket fell form where it was propped up and hit the radiator putting a hold in it.
I started following the RAVE to pull the radiator out of my 99 parts DII and my 00 DII , I got the the trans/oil cooler lines. What a PITA. Searched and found some tips that I can separate the coolers form the radiator in the DII. I will try to finish tomorrow.
Hopefully the radiator out of my parts DII will still have me running at 194 degrees.
Old Dec 22, 2013 | 08:22 AM
  #1070
Chrisinhouston's Avatar
Glad to see you are raising that child up to appreciate a Land Rover!
