Old Mar 17, 2015 | 01:02 PM
  #2561
CBRacerX's Avatar
Pins came today (thanks Atlantic British for fast service!) and got the front axle finished. Took a test drive and the brakes are much better at initial engagement. No more scary bad bearing sounds. ABS works fine.
But, it is not all a happy story - the "three amigos" are still with me despite a 20 minute test drive
Originally Posted by CBRacerX
Started what should have been an easy project - replace the front wheel bearings (one bad for sure) and do new rotors, pads and fluid on all 4 wheels.
Easy, for anything other than an old Disco2 driven in the Northeast for all of its "life."
The bearing removal and replacement did not give me too much trouble.
However, I ended up with two stuck caliper guide pins on the front - one on each brake bracket. And no amount of heat or PB Blaster freed one of them. The other finally succumbed to a full size pipe wrench and heat.
I ordered new pins all the way around and drilled out the stuck pin on the press. So maybe in a few days the Disco will be mobile again...
Old Mar 20, 2015 | 10:16 AM
  #2562
Hosk3t's Avatar
5th Gear
Found that the inside of my windshield had become an indoor waterfall. fortunately i had planned on taking the headliner out and painting it with some kind of rubberized protector anyway so it wasn't much of a problem. When i got the headliner out i discovered that both plastic connectors for the sunroof drain had been broken off. I went to ACE and got 2 hose barb/connectors and sanded one side until it slid into the plastic drain tub. So far so good.
If anyone decides to use bedliner instead of carpet make sure you use a spray and not the roll on. No matter how i mixed the can there were always giant clumps of rubber left behind.
Old Mar 20, 2015 | 08:58 PM
  #2563
Joemamma1954's Avatar
Got my windshield replaced, Non heated windshield installed for 229.00. old windshield had a crack on passenger side until the temp here in austin, tx, fluctuated from 70's to 20's, back to 70's. Crack went all the way across to drivers side. Could not find a heated one in stock here, so went the cheaper route. Really not needed here in central Texas anyway. Also replaced drivers side rear tail light assy. Had crack and water inside, so ordered one from Advance Auto, came complete bulbs and all, fit and works flawlessly.
Old Mar 21, 2015 | 07:02 PM
  #2564
thesoundguru's Avatar
Installed roof rack ladder. Picked one up on sale last weekend from Atlantic British for 78.95.
Old Mar 22, 2015 | 06:42 PM
  #2565
Clockwork John's Avatar
Today I did an oil change and replaced the cracked, glazed, slipping serpentine belt. Never did a lot of wrenching before. Figure I should start, since I can't really afford to pay the hourly rate at the one shop in town that works on European cars...
Old Mar 22, 2015 | 09:45 PM
  #2566
Robert Booth's Avatar
Got Alfred muddy this weekend. And pulled a Toyota out of a ditch.
Old Mar 22, 2015 | 10:11 PM
  #2567
ls1morethanyou's Avatar
closer and closer
Old Mar 23, 2015 | 05:01 AM
  #2568
Sir Axlerod's Avatar
sold the donor rig. Now I'm left with a DII with no trans t-case...
FML...
Time for a new job, one I can make more than $0.00 paychecks at.
Old Mar 23, 2015 | 09:13 AM
  #2569
04duxlr's Avatar
Originally Posted by ls1morethanyou
closer and closer
Looking good. You should grab a plenum filter for the HVAC intake. It will help keep leaves and other crap out of the blower.
Old Mar 23, 2015 | 12:37 PM
  #2570
good idea! i know i had a few leaves in the blower
