Old Mar 5, 2017 | 05:23 PM
  #3741
rossagge's Avatar
Originally Posted by Jeff Blake
Nice work on the grill. I want to tackle this soon... I've got my eyes on some Stainless steel woven wire mesh from Mcmaster-carr.
Thanks. Just finished it up. See below. Steel mesh will have a nice look!
Old Mar 5, 2017 | 05:26 PM
  #3742
rossagge's Avatar
Just finished up my grille. Not finished off the way I want it. Need to find some black hardware to secure it the way I want. Just used zip ties for now and 3M'd the LR emblem. Also replaced all amber markers and high beams. Installed amber high beams just to see what they look like. Prob will replace with the white. Waiting on lows to come in.
Old Mar 5, 2017 | 05:34 PM
  #3743
rossagge's Avatar
Originally Posted by disco203lr
Can't wait to see what it looks like back on the truck.
It's on!
Old Mar 6, 2017 | 03:09 PM
  #3744
JUKE179r's Avatar
I finally worked on my cooling system.
- Flushed the whole system and heater coil 4x until clear
- Hayden Automotive #2781 Premium Fan Clutch and the Dorman #620-112 Radiator Fan Assembly - $60
- aluminum coolant hose T connector from Canada - $85
- replaced upper 3 radiator hoses #PCH000460 - $30
- 180 degree soft spring thermosat - $35
- 2 gallons of Zerex G-05 coolant - $40
- new expansion bottle cap - $10
- 2 hours of bleeding the coolant system to perfection.
It's been 2 days and my temps are way lower than before. My Disco used to sit idling at 221 degrees now it's sitting at 190-192 degrees.
Cruising around Atlanta now at 50 MPH the temps average around 186 to 188 degrees.
Should I have done the thermostat mod? It would have been cheaper but I'm very pleased with the results so far.
Old Mar 6, 2017 | 04:51 PM
  #3745
slanginsanjuan's Avatar
Default rust control and waterproof
...well I could have done this in one day if I got up really early and went to bed really late...and didnt drink a lot.
so i "grinded" the rust off. I epoxied the crushed aluminum cans in. i filled it with bondo and i painted it with special rust paint.
dont know about rust inside the massive hole or any bad reactions between steel and aluminium but i'll get some years out of this for sure.
gonna deal with that roof paint soon. gonna see if there are other leak spots too. tired of that wet rig sht.
Attached Thumbnails What did you do with your DII today?-20170228_162914.jpg   What did you do with your DII today?-20170302_160229.jpg   What did you do with your DII today?-20170302_160210.jpg
Old Mar 6, 2017 | 09:13 PM
  #3746
disco203lr's Avatar
- soft spring thermosat - #35
- expansion bottle cap - $10
Nice! I live in Atlanta too. What program/equipment are you using to get that data?
Old Mar 7, 2017 | 06:48 AM
  #3747
zoltan7's Avatar
Looks great!!!
I think you're fine for that. True testiment is inner city driving or trail driving. You want to be 200-210 for those things.
When you flushed, did you just disconnect lower hose at thermo and push water through the top hose?
Old Mar 7, 2017 | 08:08 AM
  #3748
The Deputy's Avatar
Default New meats.
Old Mar 7, 2017 | 08:14 AM
  #3749
cosmiccharlie's Avatar
Where did you order the aluminum T?
Old Mar 7, 2017 | 12:04 PM
  #3750
JUKE179r's Avatar
I'm using the Ultragauge Blue OBDII adapter and their App on my iPhone 6S+. I like it because you can modify what you want to specifically monitor on your Disco.
Originally Posted by zoltan7
Looks great!!!
Thanks zoltan!
I first left all the hoses connected and but then I disconnected every hose possible to include the both drain plugs from the LH & RH side of the engine to clean out every internal nook and cranny of the engine. Time consuming but well worth it for the results.
I bought it from berbervanri on eBay Canada...
Land Rover Discovery 2 Coolant Hose "T" connector eBay
