#4462
#4465
Received 1,187 Likes
on
Switch panel cover repair.
While changing both interior boots (brake/hi-lo) on wife's rig, notice three of the four insert pins were missing on the switch panel cover. Took a 1/16 drill bit and drilled down into the portion of the cover where pins had broken off, the area is slightly raised, so you can drill into cover about an 1/8 inch. Used the shank of a 1/8 used pop rivet, cutting the pieces to length (1/2). Then super-glued them into drilled holes.
Not the greatest pictures, but pretty self explanatory.
Brian.
Brian.
#4466
Steam cleaned my Discovery 2 TD5 2001 RHD auto ES after finding red atf fluid leaking below the area where the transmission intercooler and radiator is positioned. I cannot see the source of the leak as the cross member obscures this area. Any ideas what element could be the culprit. With the engine running there is a steady drip of red fluid from this area?
#4468
The Deputy (09-16-2017)
#4469
Armrest Cupholder
Old cupholder
New cupholder from pull your part
Finally got around to fixing the rear armrest cupholder. Wasn't super high on the to-do list, but it was bugging and it was the last cracked/broken item in the entire interior. Only posting this because these things are STUPID hard to find intact.
