Old Sep 13, 2017 | 02:00 PM
  #4461
No Doubt's Avatar
Originally Posted by stillruns
Tires are in. I appreciate the design and think it compliments the D1. These are Treadwright tires. I drive it less than a 1000 miles a year, no need to spend a grand on tires. I got 4 of these for less than $300.
Where did you find them for just $300?!
Old Sep 13, 2017 | 05:54 PM
  #4462
stillruns's Avatar
Treadwrights website. They are the ATG's. 10% off after the Houston flooding. I believe Treadwright is HQ in Houston. The regular price for them is still good imo.
Old Sep 13, 2017 | 05:56 PM
  #4463
stillruns's Avatar
Thank God you had it tucked before someone snapped a photo and posted it on this forum!
Old Sep 13, 2017 | 06:02 PM
  #4464
Jeff Blake's Avatar
Antennas
Old Sep 15, 2017 | 07:56 PM
  #4465
The Deputy's Avatar
Default Switch panel cover repair.
While changing both interior boots (brake/hi-lo) on wife's rig, notice three of the four insert pins were missing on the switch panel cover. Took a 1/16 drill bit and drilled down into the portion of the cover where pins had broken off, the area is slightly raised, so you can drill into cover about an 1/8 inch. Used the shank of a 1/8 used pop rivet, cutting the pieces to length (1/2). Then super-glued them into drilled holes.
Not the greatest pictures, but pretty self explanatory.
Brian.
Old Sep 15, 2017 | 11:34 PM
  #4466
MLX665GP's Avatar
6th Gear
Steam cleaned my Discovery 2 TD5 2001 RHD auto ES after finding red atf fluid leaking below the area where the transmission intercooler and radiator is positioned. I cannot see the source of the leak as the cross member obscures this area. Any ideas what element could be the culprit. With the engine running there is a steady drip of red fluid from this area?
Old Sep 16, 2017 | 04:36 PM
  #4467
The Deputy's Avatar
Default Pictures or it didn't happen...
Both boots installed.
Happy wife, happy life...so they say.
Brian.
Old Sep 16, 2017 | 04:56 PM
  #4468
No Doubt's Avatar
Brian.
Looks good.
Old Sep 16, 2017 | 09:50 PM
  #4469
MacRoadie's Avatar
Default Armrest Cupholder
Old cupholder
New cupholder from pull your part
Finally got around to fixing the rear armrest cupholder. Wasn't super high on the to-do list, but it was bugging and it was the last cracked/broken item in the entire interior. Only posting this because these things are STUPID hard to find intact.
Old Sep 17, 2017 | 11:28 AM
  #4470
Codyt's Avatar
Out near Blewet pass WA. Smokey and dusty!
