Old Oct 17, 2017 | 08:40 PM
  #4541
LR03NJ's Avatar
Default HG
Old Oct 17, 2017 | 10:14 PM
  #4542
Jwehking's Avatar
Is that paint or bare aluminum?
Old Oct 17, 2017 | 10:49 PM
  #4543
Twix's Avatar
Replaced my blower motor. Still no air through the vents. Voltage at connector, cut the connector and hardwired. Have voltage, but no spin. I think the ground is gone, but I need a schematic to find out where it goes.
Old Oct 18, 2017 | 07:31 AM
  #4544
LR03NJ's Avatar
No paint, all bate. I just clean them up.
Old Oct 18, 2017 | 02:58 PM
  #4545
The Deputy's Avatar
Good thinking. You should never, ever paint any aluminum engine block/heads/trans/transfer case/etc/etc. The beauty of aluminum is its heat transferring abilities. Paint neutralizes its ability to do so.
Man, you've been busy on that engine. Nice work. If she runs half as good as she looks...you should have a winner.
Brian.
Old Oct 19, 2017 | 01:40 AM
  #4546
No Doubt's Avatar
Whoa! What a page for this thread. Fantastic roof rack and a head gasket that covers the liners so no more Tick.
Well done, gentlemen.
All that I did on my Disco 2 today was hand cut neoprene window/door gaskets to finally eliminate road noise from wind.
Old Oct 19, 2017 | 02:50 PM
  #4547
LandBeard's Avatar
Originally Posted by MacRoadie
Replaced old, worn out roof rack with new BajaRack. Got front and rear lights mounted, as well as hi-lift and axe/shovel mount. Waiting for awning mount to arrive. Also, went with 1/2 floor this time, leaving front half of rack open for flexibility.
That Baja rack is dope! Eventually will get one and do a similar set up with aux lights across the front. Always need more light with how dim the older headlights are. Great job!
Old Oct 19, 2017 | 02:51 PM
  #4548
LandBeard's Avatar
Inspiration while I have my manifold off! Looking good Gerry!
Old Oct 19, 2017 | 05:22 PM
  #4549
Jeff Blake's Avatar
Put in RTE 3" rear springs, d1 spring seats, and d1 spring retainers.
Holy moly the ride difference blows the terrafirma HD's out of the water (quick pavement test with lots of dips and bumps). And now I'm happily at 21" from wheel center to bottom of wheel arch all around.
I have the RTE front springs as well, uninstalled, but everything looks really good so I'll probably leave it for now... take it on a few offroading trips first to gauge the difference.
Old Oct 20, 2017 | 09:20 AM
  #4550
JUKE179r's Avatar
I finally bought the parts to do my Big 5 cable upgrade.
I'm doing the negative cables first:
  • 0AWG from battery - to chassis
  • 0AWG from engine to chassis
  • 0AWG from alternator chassis to battery -
The positive cables I'll do a bit later:
  • 0AWG from alternator + to fuse link to battery +
  • 0AWG from battery + to starter +
Battery cable upgrade
