Old Apr 2, 2018 | 11:41 AM
  #5071
Saturnine's Avatar
Spacers suck. Where is it rubbing?
Old Apr 2, 2018 | 03:27 PM
  #5072
Alex_M's Avatar
I would not recommend 1/4" spacers. You need to keep your wheels Hub Centric. If you're doing spacers, get a quality brand such as BORA. Cheap spacers kill people. Most things I'm a cheap skate on, but not wheel spacers.
Probably the thinnest you'll get in hub centric are 1' or maybe 1-1/4", and you'll have to trim the studs at that length.
Old Apr 2, 2018 | 04:42 PM
  #5073
Twix's Avatar
You can get hub centric 5x120mm spacers as thin as 5mm
Old Apr 2, 2018 | 04:57 PM
  #5074
Alex_M's Avatar
Do they keep the rim hub centric, too?
Old Apr 2, 2018 | 06:10 PM
  #5075
Twix's Avatar
Yes, they use the factory ring up to around 12mm, after that they have their own ring
Old Apr 2, 2018 | 07:32 PM
  #5076
redrover75's Avatar
Had my new ride checked for oil pressure, well over the spec, 65psi+. So that it good. No leaks in coolant, oil, shop thinks my ticking is the drivers side lifters. So will start researching that.
Quick question, when I unlock the car w the fob, sometimes the alarm does not turn off. The alarm goes off when i open the door. Does anyone have a suggestion for where to start?
Old Apr 2, 2018 | 07:35 PM
  #5077
Jeff Blake's Avatar
65 psi shouldn't be possible, the relief valve in the front cover regulates it to a max of 50.
Old Apr 2, 2018 | 09:24 PM
  #5078
LR03NJ's Avatar
Removed bumper and fender.
Old Apr 3, 2018 | 01:30 AM
  #5079
Disco Dad's Avatar
I did a complete body panel swap from a dented up white to white gold. The white roof looks like a nod to the old Rovers. Flipped the spare tire carrier to accommodate the 245/75/16 Treadwright claw. Installed a snorkel as well
Old Apr 3, 2018 | 08:05 AM
  #5080
CollieRover's Avatar
That's awesome! I was thinking about painting my roof, but you just swapped the whole panel? How many man job was it? Did you reinstall the windows/sunroofs etc. yourself?
