Old Apr 22, 2018 | 06:54 PM
  #5201
CollieRover's Avatar
Originally Posted by Saturnine
That some new British prototype?
Old Apr 22, 2018 | 09:27 PM
  #5202
Saturnine's Avatar
Prototype BS perhaps
Old Apr 22, 2018 | 09:28 PM
  #5203
Saturnine's Avatar
Old Apr 23, 2018 | 10:05 AM
  #5204
Jeff Blake's Avatar
I went trail running and camping to test out the latest work I've done. The buzzing of the traction control system is stuck in my head. Everything worked very well. Front hub seal is holding strong, as is the diff pinion seal. Having working radius arm bushings is a god send. Very happy with the terrafirma adjustable shocks... the settings actually make a difference. Used the winch once. Need to get my CDL project finished for sure
On the way home, got a P0101 code. Tried putting in a new MAF and resetting adaptive values, p0101 is now pending. Long term trims are now at +7.5% (up from 3%) after the 50 miles home. Also seeing an intermittent code 38 (P1884) Altitude invalid on the transmission ecu. Hmmm
Power seems low... I struggle to push 50 mph going up 8% grades. Truck wants to stay around 3k rpm in 3rd.. if I give it any more it shoots to 4200+ rpm in 2nd (and get screeching sound). Think I need to do a compression test. Loud high pitched ticking appears to be coming from the fuel rail...
Old Apr 23, 2018 | 12:02 PM
  #5205
Hans L's Avatar
Installed OME Medium Duty Springs and Nitrocharger Shocks this weekend. Netted about 1.7" of lift. Adding bigger tires next.
Before - After:
Best tip ever to avoid having to use spring compressors - use a Bottle Jack:
Old Apr 23, 2018 | 12:48 PM
  #5206
mollusc's Avatar
Do you drive your truck upside down so it doesn't get dirt on the undercarriage??
Old Apr 23, 2018 | 01:49 PM
  #5207
JUKE179r's Avatar
Gotta love a California kept truck!
Old Apr 23, 2018 | 02:33 PM
  #5208
Hans L's Avatar
Ha! Yeah, the San Diego climate does help. No rust/corrosion issues to deal with. But uh, I did scrub the front end suspension areas before I started the job..
Old Apr 23, 2018 | 04:13 PM
  #5209
Psycho_Taco's Avatar
I replaced the leaking brake master cylinder with a new unit from L8. Bleeding the brakes was surprisingly easy with a helper, and I no longer have to two-step to brake effectively! I also replaced the POS plastic switch panel in between the seats with a solid faux-wood one that runs the length of the center console, much sturdier. This afternoon I'm going to take apart the driver-side mirror to see why it isn't defrosting, and put grip tape on my tree bars.
Old Apr 23, 2018 | 08:31 PM
  #5210
Twix's Avatar
I didn't work on the rover today, but I got back at a set of wheels I've been meaning to strip and refinish. I accidentally left the first one in the chemical bath over night which corroded the **** out of the aluminum. Now I have a lot more work ahead of me, but I can see progress slowly. The other 3 are getting mechanically stripped by hand as the hard anodizing isn't as hard as I originally anticipated. Here's some pics:
