Old May 3, 2018 | 07:33 PM
  #5271
Jeff Blake's Avatar
I put in a Dorman 620112 fan and Hayden 2991 fan clutch fully expecting a healthy drop in temps, but nope, 2 degrees hotter at idle.
On the plus side, I put in a new crank pulley... no more wobble.
Oh and put in extended bump stops
Old May 3, 2018 | 07:48 PM
  #5272
Best4x4's Avatar
2F warmer thats interesting. I've seen 1-2F the other way or exact same depending on the fan clutch used.
Old May 3, 2018 | 07:49 PM
  #5273
Saturnine's Avatar
Hmm.. That kinda stinks. I bought the same setup
Old May 3, 2018 | 08:14 PM
  #5274
No Doubt's Avatar
Are the fan blades backwards??
Old May 3, 2018 | 08:16 PM
  #5275
Jeff Blake's Avatar
It only really goes in one way. Side labeled front points to the radiator
Old May 3, 2018 | 08:17 PM
  #5276
No Doubt's Avatar
Talking
I'm talking about the direction that the blades are mounted on the fan clutch, not the direction that the fan clutch is mounted to the crank.
Old May 3, 2018 | 08:19 PM
  #5277
Saturnine's Avatar
I'm sure he's talking about the fan blade -- i have the same setup and it really only goes together one way
Old May 3, 2018 | 08:20 PM
  #5278
Jeff Blake's Avatar
So your "Front" faces the rear?!
Anyway, I'm talking about the direction that the blades are mounted on the fan clutch, not the direction that the fan clutch is mounted to the crank.
No doubt!
Yeah I hear you, but so there's only one way to assemble it together. Air is sucking through the radiator into the engine bay if that helps clarify it
Old May 3, 2018 | 08:22 PM
  #5279
No Doubt's Avatar
Talking
OK, ok... so I'm the only guy who can get that backwards?!
Where's the raspberry emoji?!
Old May 3, 2018 | 08:23 PM
  #5280
No Doubt's Avatar
We can all agree that the fan clutch only goes onto the motor one way (big nut!), but was I hallucinating that the fan blades could go onto the fan clutch 2 different ways?
