Old Jul 29, 2017 | 04:39 PM
  #4271
jringeno's Avatar
Installed a 180F thermostat today, flushed the coolant w/ new stuff. Dropped my idle temp almost 20F.....quite impressive IMO.
Also helped a guy replace a coil pack on his mercury cougar on the side of the highway....+1 karma!
Old Jul 29, 2017 | 05:28 PM
  #4272
04in719's Avatar
Junk yard score. Out of a 4.6 Rangie. Genuine Bosch LR 150Amp Alternator. Tests out good, the RR donor only had 95k on it. $30 bones, not too bad I think.
Old Jul 29, 2017 | 06:29 PM
  #4273
Luckyjayb's Avatar
Originally Posted by Jeff Blake
thanks
hard to say exactly, as when I put that in I also rebuilt the engine, replaced all the cooling components, etc.
my temps are pretty good though, 190-194 freeway, 203 at idle in socal.
where did you get the hood liner jeff
Old Jul 30, 2017 | 04:27 PM
  #4274
1811SAR's Avatar
Default Dual Battery Source
Engine bay relay panel! Hoping to add some front floods and a LED bar in the near future.
Who makes the dual battery system you have there Jeff? Is there a good source you would recommend?
Cheers mate,
G
Old Jul 30, 2017 | 07:14 PM
  #4275
Jeff Blake's Avatar
Cheers mate,
G
It's made by blue sea systems. A boat company. Ml-acr-7622 I believe. It's amazing. I researched options a ton and this is definitely the way to go. Other systems like the national Luna are terrible in comparison.
Old Jul 30, 2017 | 07:16 PM
  #4276
dtmbinb's Avatar
Installed a Safety Devices roof rack today. It fits like a glove!
Old Jul 30, 2017 | 07:28 PM
  #4277
Jeff Blake's Avatar
Installed some lights on the front light bar. I couldn't use the stock holes because they are too far back so I'd have to cut up the grill and wouldn't have access to the winch clutch anyway. So I bought some 1/8" pipe clamps (half circle with 2 flat mounting holes) and put them under the bar. One hole bolts to the stock hole, then the other hole is used for the light so they sit out front.
These are Amazon specials, I think 30 bucks for the pair. They have cree's, and are very well built, so I can't really justify spending hundreds of dollars for name brand lights.
though I do plan to drop $700 for he front runner 40" roof rack led bar soon
Old Jul 30, 2017 | 07:47 PM
  #4278
LR03NJ's Avatar
Replaced brake rotors and pads.
Old Jul 31, 2017 | 03:44 PM
  #4279
1811SAR's Avatar
Default Dual Battery System
Where did you get the batteries? I see that Blue Seas sells the add-a-battery kit. Where did you source the batteries my friend?
Cheers,
G
540.422.3918
Old Jul 31, 2017 | 04:40 PM
  #4280
Jeff Blake's Avatar
Cheers,
G
540.422.3918
They are Odyssey Group 34's. From 4wheelparts, but shop around on prices...
