Old Jan 5, 2020 | 05:34 PM
  #7081
No Doubt's Avatar
Originally Posted by Sixpack577
Crower claims 20-22hp and 30-32' lbs of torque.
Not too hard to belive, as you can easily see the difference in duration.
Stock left, Crower right.
I definitely have more power with that cam after my rebuild, and my idle purrs just right. No loping. Highly recommend.
Old Jan 5, 2020 | 11:01 PM
  #7082
Fastercat's Avatar
I’m glad you got it I figured out six pack. Easy mistake and easy fix.
Old Jan 7, 2020 | 10:59 AM
  #7083
CollieRover's Avatar
Crank is in...again...but it's right this time, lol.
Note to self, and word to the wise...stop working on things when you are tired.
I bag, tag, and label everything, and don't mix parts(since I'm working with 2 engines), but, screwed up, obviously.
I grabbed the 4.6 crank...and the 4.6 main bearing caps.
When I should have picked up the 4.0 main bearing caps that go with the 4.0 block I'm using.
Granted, the 4.0 and 4.6 caps Are the "same", and I am using stock bearings. But, we are dealing in thousandths of an inch, and the 4.6 caps were from the other block.
So, without a line hone, they were apparently just a little too tight.
I put the 4.0 caps in, measured, they're in spec, reassembled and torqued it all...and the crank spins freely, as it should!
Fortunately, I had bought 2 sets of cruciform seals too, so I had a new set for the other rear main cap.
Yay! Go dummy me!
But, I still hate this thing, lol.
On to gapping rings and finishing the bottom end now.
Note the different color main caps in this picture.
Haha! Tired don't help nobody.
Gonna be a beast when you are done.
Old Jan 7, 2020 | 11:31 AM
  #7084
Sixpack577's Avatar
Man I hope so, because if it doesn't work this go'round...I am done.
Old Jan 7, 2020 | 05:45 PM
  #7085
No Doubt's Avatar
To celebrate 2020, I'm switching to full-time Sport Mode. That really awakens the Crower performance cam!
Gas mileage in these beasts is pointless, anyway. Time for fun!
Old Jan 7, 2020 | 06:34 PM
  #7086
Sixpack577's Avatar
What does Sport Mode do anyway?
Just changes the shift points/shifts at higher rpm's?
Old Jan 8, 2020 | 02:44 AM
  #7087
JUKE179r's Avatar
Basically... and get sh!tty gas mileage. lol
I only use Sport Mode when passing. Eek....
Old Jan 8, 2020 | 10:17 AM
  #7088
Dave03S's Avatar
A lot of people report better MPG using sport mode, the button, not the foot on the pedal.
Old Jan 8, 2020 | 10:28 AM
  #7089
Sixpack577's Avatar
It's possible, but depends on elavation, roads(lots of hills vs flat highways), stop and go vs highway.
Holding a gear longer vs lugging the engine can also change things.
Too many variables.
I am curious to see with porting and a Crower cam, how good of mpg it can get on the highway(17mpg?? mayyybe)...then it's back to real driving and single digits, lol.
Old Jan 8, 2020 | 07:23 PM
  #7090
PPorBust's Avatar
Twisted my nipple (!), removed front drive shaft, drove in to work. That plus the extra little light on the instrument panel makes me 99% sure I've got the locking center diff. :😎
Got the driveshaft apart and cleaned up. Not as easy as I hoped, not as hard as I feared.
