Old Feb 28, 2020 | 11:06 AM
  #7251
Sixpack577's Avatar
Originally Posted by Geordon Sparks Orbical Taylor
hey thanks for the reply! ARP makes a bolt set for the main bearing caps. They aren’t studs, but they also didn’t fit. Lol. The side bolts are a good inch shorter than the original. I did everything above and planned on measuring in different cylinders, but I still don’t understand how that helps if all the rings are the same size (per 1st, 2nd compression, and oil). Wouldn’t that mean, at this point, that I’d have at least one cylinder (#3) where the ring gap is too large?
Because all the rings and bores are Not the same size.
There is a tolerence range, and variation between each piston, ring, and cylinder.
Which is exactly why you have to file ring gaps, and why they are supposed to be made with a gap that is in the tolerance range, or smaller, which can be filed to a larger and in spec end gap.
Read post #7196
Old Feb 29, 2020 | 05:30 PM
  #7252
The_OGCJR's Avatar
Originally Posted by whowa004
RTE 3" springs with TF +3" adjustable shocks, so roughly 11" of shock travel per side. Relocation cones and spring retainers. This weekend I plan on throwing 1" spacers back in the rear just to level things out a little more. I plan on picking up a RTE extended watts linkage this spring hopefully. Oh and no sway bar and extended brake lines. The tire will tuck up inside fender, pic for reference on old worn out springs.
nice. I unseat the front and I need to figure out how to retain the tops.
the rear doesnt unseat because I still have the stock watts
Old Feb 29, 2020 | 05:34 PM
  #7253
The_OGCJR's Avatar
Installed my new bumper
Old Feb 29, 2020 | 07:00 PM
  #7254
Sixpack577's Avatar
Looks good
any side pics?
Old Mar 1, 2020 | 04:39 PM
  #7255
777AIA's Avatar
Originally Posted by Rover De Land
Kinda like the DI side, but include what you did to it AND with it.
Low key day. Wash and wax on D2 and the Sertao. She cleans up pretty good for a 2000.
Old Mar 1, 2020 | 08:18 PM
  #7256
The_OGCJR's Avatar
Originally Posted by Sixpack577
Looks good
any side pics?
will post one tomorrow
Old Mar 1, 2020 | 10:53 PM
  #7257
MrValingo's Avatar
One of these things is not like the others
Old Mar 2, 2020 | 06:43 AM
  #7258
Kalliste80's Avatar
Default Exhaust Leak Fix
After about six weeks of hearing what I thought was an exhaust leak, then thinking it was a slipped sleeve, was actually an exhaust leak after all. For some reason the three bolts that connects the manifold to the exhaust pipes on each side (before the catalytic converters) were a bit loose. After spending about 15 minutes tightening the bolts up, it now sounds perfect.
Old Mar 2, 2020 | 09:56 AM
  #7259
jastutte's Avatar
gotta love an easy fix.
Old Mar 2, 2020 | 12:52 PM
  #7260
RossN99's Avatar
Took my 03 with 248,000 miles on a 500 mile round trip on Saturday up to the smokies to see some snow. There was about a foot of snow in some of the shadier spots and by far the most snow I’ve ever seen. I was amazed at how well the truck did going up the mountain considering it has a tendency to be sluggish in some situations.
