Old Mar 28, 2020 | 12:51 AM
  #7321
Richard Gallant's Avatar
Wonder if the shop did not get the bolts torqued right, that sounds like the heads were not correctly torqued to me
Old Mar 28, 2020 | 02:30 AM
  #7322
The Deputy's Avatar
Originally Posted by RossN99
So my project truck that has been a nightmare since the day I bought it has continued to test my patience. I wasn’t even going to buy the thing but I let my dad convince me it’d be a nice purchase since it was an HSE7 and what’s the worst that could happen. Well 10 months later I still have it in pieces and it’s still not right. So I had the engine rebuilt and I finally got it back from the shop and installed it but unfortunately my excitement about getting my truck running again was short lived. First the oil pressure switch had failed so it appeared I had low oil pressure which luckily I did not. Then when I finally installed all of the cooling system and ran the truck for a little bit to bed in the cam I noticed I was hemorrhaging water midway on the block on both sides which I thought was really weird and then I checked my oil fill cap and guess what it’s milky. So first I think my machine shop somehow messed up installing my freeze plugs as I’m not sure how else water could be coming from mid block and second I can’t decide if I somehow messed up installing my headgaskets or if it’s the Lucas break in additive I added that’s left this yellow foam on the cap as the oil still looks clear elsewhere. This is probably my 5th time doing head gaskets on a rover V8 and this block had no issues with overheating/water loss prior so I’m a little dumbfounded.
Weird that you would have coolant leaking mid-block, since coolant passages are located at rear and front of head...if coming from head gasket. I'd check freeze plugs, but they produce a coolant leak eternally, not internally...so, that would not explain the milky oil. Was that oil filler tube clean to begin with? Since, they do get kind of milky looking just from condensation burn off. Pull the dipstick and check oil quality there...or let it sit for a whilw and drain some from pan. If anti-freeze is present, it will come out first...since it is heavier than oil. If you have collant in the oil, my first guess would be front cover gasket is messed up or you didn't use sealant on the three bolts that go through the water pump/front cover. Coolant would leak internally there, head gasket not so much. Usually a head gasket will leak externally or into the cylinder (#1,#2,#7,#8) and just exit through the exhaust while running...unless...it's a whooper of a head gadket leak...but normally...you'd have all kinds of misfire codes if that were the case and a very poorly running engine.
lf engine runs smooth, l'd start by checking for anti freeze leak at throttle body heater or heater hose on passengers side.
Brian.
Old Mar 28, 2020 | 09:51 AM
  #7323
RossN99's Avatar
Unfortunately it’s most definitely the freeze plugs. Which I’ve gone ahead and taken off some stuff to get a better view at. The oil in my dipstick was crystal clear and there was no steam out the exhaust which is making me think the headgasket is fine but maybe there was just some moisture already in the system that’s collected in the cap. I even pulled the valve covers off to get a view and they didn’t have any of the yellow foam in them and honestly the cap may not have been clean before who knows. It’s just disappointing about the freeze plugs because my shop normal does much better work.
Old Mar 28, 2020 | 10:04 AM
  #7324
Kalliste80's Avatar
[QUOTE=Motoprophet;723317]Replaced the head gaskets on my newly acquired ‘04. I ordered headliner material so that will be in the near future. BTW my flywheel bolts for my LR3 came in today, finally![/QUOTE
You probably know, but always good to check for any leaks in the sunroofs while the headliner is down. I wish I had done this!
Old Mar 28, 2020 | 10:52 AM
  #7325
Sixpack577's Avatar
Did they put any sealant on the freeze plugs?
They are supposed to.
Old Mar 28, 2020 | 11:14 AM
  #7326
RossN99's Avatar
Doesn’t appear to have any. He’s a fan of using this sealant that’s brown and I think if he’d used any it would have been obvious.
Old Mar 28, 2020 | 11:16 AM
  #7327
Sixpack577's Avatar
That sucks, no wonder they're leaking.
The shop would be hearing from me.
Old Mar 28, 2020 | 12:10 PM
  #7328
RossN99's Avatar
oh he will be but he’s closed until Monday.
Old Mar 28, 2020 | 01:38 PM
  #7329
The Deputy's Avatar
At least it is the least serious of problems, pain yes, but the engine doesn't need to come a part. Plus, it is something they can redo at the shop...their mistake, their repair.
Old Mar 28, 2020 | 04:44 PM
  #7330
Kalliste80's Avatar
Default Made my own Airbox Fabric Flex Hose
Today, I decided to try and make my own flex hose that connects to the air box and save about $50. I put the write up where I thought it belonged:
https://landroverforums.com/forum/di...e3/#post723799
Thanks!
