Old Apr 8, 2020 | 08:52 AM
  #7361
The_OGCJR's Avatar
Originally Posted by boston4
Went out in hopes of finding the leak in my AC system so that I can order the appropriate replacement parts and have an enjoyable summer in the truck. Turns out that the system only holds a vacuum for a couple minutes - there's a really substantial leak somewhere. On top of that, the can of refrigerant/dye that I'd purchased turns out to be defective so I couldn't check to see if my compressor works or where the leak is.
I'm really close to just having the local Rover shop deal with this - I shudder thinking about spending $1k on air conditioning but this just seems like a nightmare to work with.
you can buy a leak detector kit from autozone. It may still be simple. I’ve seen Schrader valves stick open and all the freon leak out. It’s not likely but it can happen.
Old Apr 8, 2020 | 09:05 AM
  #7362
boston4's Avatar
Remove your grill and look at the small A/C line that runs between drivers side headlight and radiator to condensor, common place for a leak. The line is held in place with a mounting clip there and rots out from salt and corrosion.
Brian.
Thanks Brian - this is helpful. I reordered a new testing set so I'll start there. Ideally I don't need to replace the condensor or the line from the drier to the evaporator.
Thanks - the valves seem OK (and both high and low were connected to the gauge set when I pulled a vacuum. I held off on charging the system but will do so once I get a new dye kit.
Old Apr 8, 2020 | 06:54 PM
  #7363
Blackrain's Avatar
Got my rear turn signal issue figured out.... loose connection at the housing end plug and defective bulb on passenger side. Drivers side was a whole other story... who ever replaced the bulbs didn't turn them to lock them into place ... quick turn and ... bingo... working rear turn signals...
Old Apr 10, 2020 | 01:06 PM
  #7364
escott16's Avatar
While quarantined I got bored and coated the underside with Eastwood rust encapsulator, not perfect but aslong as it works
Old Apr 10, 2020 | 02:21 PM
  #7365
wjsj69's Avatar
[QUOTE=huggi;724998]Painted the rims black
Kudos for going gloss instead of the popular flat. Flat looks cheap and dirty even if it's clean imo.
Old Apr 10, 2020 | 06:56 PM
  #7366
ALDisco's Avatar
Default Cheap fender fix
Got a can of rustoleum rubberized undercoat, taped off the body, and got the fender flares cleaned up some for cheap.
Old Apr 11, 2020 | 07:30 AM
  #7367
TheBestCow's Avatar
@escott16 that looks really good, nice job.
@huggi I think you must be the same person who posted a video of an entire fleet of LRs on reddit recently?
Old Apr 11, 2020 | 05:31 PM
  #7368
Boostle's Avatar
Recently bought a 2001. 1 owner with 56k miles. The quarantine got me motivated to work on the truck.
OME HD springs
1inch spring spacer
Utah HD driveshaft
Fox shocks and steering stabilizer
Upgraded watts linkages SS Lines and extended abs lines
03-04 grille
wireless rearview camera
method 701 wheels
285/75/16 wildpeak at3s
Waiting for my lucky8 winch bumper to arrive!
Thanks to my go to companies atlantic British and lucky8.
Old Apr 11, 2020 | 06:19 PM
  #7369
boston4's Avatar
OME HD springs
1inch spring spacer
Utah HD driveshaft
03-04 grille
method 701 wheels
looks great - what’s the wireless camera you installed?
Old Apr 11, 2020 | 06:49 PM
  #7370
Boostle's Avatar
AUTO-VOX T1400 Upgrade Wireless Backup Camera Kit on amazon. Mirror swaps out super easy. Comes with the needed adapter. No wires to run through the cabin. You just need to tap into the reverse light.
