Old Jul 3, 2020 | 08:51 PM
  #7651
Fastercat's Avatar
Started to assemble my motor
Has anyone used these bearmach chain wheels before? There’s no machining
Old Jul 4, 2020 | 12:21 PM
  #7652
Discorama's Avatar
Originally Posted by Kalliste80
Discorama, looks like a lot of fun. Question: what's that box on top? Is it a tent? Also curious how its affixed to your roof. Thanks!
It's a water tank with solar heater. The tank is insulated, so it doesn't cool down too much over night. I used these here for attaching: https://www.ebay.com/itm/191682643828 (same seller). They fit perfectly on the '04 roof rails.
Old Jul 4, 2020 | 07:11 PM
  #7653
redwhitekat's Avatar
I had a Porsche 911 once and I remember this old guy tell me if I wanted it to run and purr track it a few times. I did I guess it will clean up a lot of sludge
drove the disco 2 1/2 hours did a couple trails and drove another 2 1/2 hours.
Total of 10 hours of trails and highway of running time. Any sludge must have all burned off lol
Old Jul 5, 2020 | 10:54 AM
  #7654
The_OGCJR's Avatar
Originally Posted by Davis31052
Dude must be as old as me. Nobody puts "white Letter Out" on euro cars anymore.
well it’s been back in the tuner scene for awhile now. They actually stencil on large letters sometimes
Old Jul 5, 2020 | 10:57 AM
  #7655
The_OGCJR's Avatar
I started a paint recon on her. Before and after below:
Old Jul 5, 2020 | 10:43 PM
  #7656
Discorama's Avatar
Intake leak test with my DIY smoke generator. The jar lid has the same diameter as the MAF, so it seals perfectly. The PCV valve and the attached hose leaked a bit, which could be fixed by tightening then valve and the worm clamp. I saw very little smoke coming out at the throttle shaft when WOT, but I guess this is negligible. Otherwise I could pressurize the intake system with a hand pump, check for leaks and pull the brake vacuum line to release the pressure in the end.
Same test on the exhaust system: A Lucas bottle fits perfectly into the tail pipe. Other than the known Y-pipe leaks (I have to seal them with Permatex 81878 next time) I found a crack at the input to the muffler. Looks like I need a new muffler soon.
Old Jul 5, 2020 | 11:20 PM
  #7657
JoJo The Giraffe's Avatar
Nice DIY work. What were the results
Old Jul 6, 2020 | 08:42 AM
  #7658
arains44's Avatar
With the help of forum members I have been diagnosing lean codes. I assumed the issue was the most complex/expensive one (Injector seals, brke servo, etc.). I bought a new Bosch MAF since I had only replaced my original MAF with a used one and wanted to rule that out. $120 from Parts Geek for a genuine Bosch.
Well, guess what... Installed new MAF yesterday, codes fixed! Simplest answer many times is the right one...
Now I am seeing P1415 and P1412 for SAI system. Solving one issue at a time!
Old Jul 6, 2020 | 09:04 AM
  #7659
Best4x4's Avatar
For 1412/1415 check all vacuum lines, rubber 90's, and the main line from the pump to the metal SAI pipe.
Old Jul 6, 2020 | 11:12 AM
  #7660
Kalliste80's Avatar
I'm not too old...yet Name:  H5uKDcM.png
Size:  987 Bytes , I just really liked the look of the Disco from this guy's site: www.discovery2.co.uk/ Spare wheel carrier mod / flip
