#8092
The following 4 users liked this post by Sandman614:
#8093
Finally got around to doing Extinct’s in-line thermostat mod and replaced the fan clutch and water pump with a GMB HD clutch and a GMB water pump. This made a HUGE difference. Before, my disco would idle and sometimes run 205+. Now according to the Ultragauge, once it hits 186, it immediately drops back to sub 180. Drove it for a good hour yesterday to work the air out of the system and it never got above 190. Also replaced the hoses with new Gates hoses. Found out my reservoir tank is cracked in the process so I’ve got a new one on the way but of course I couldn’t just get a new reservoir tank. So, I also ordered some new Phillips LED backup lights and Hella high performance 2.0 high/low and fogs.
Also replaced the oil pan gasket, cleaned the pickup tubing and replaced the O-rings on it and the oil cooler piping. The pan was a mess of sludge and carbon, luckily no metal chunks or anything but took me a good hour to thoroughly clean.
Next order of business is gonna be the ATF and running a Seafoam Induction Cleaning.
#8095
Well, I had what I thought was an exhaust leak at the manifold so I took it into a very respected shop. Found out that the head gasket has gone out on the compression stroke. Have had no codes or anything else suggesting an issue mechanically. just the sound of an exhaust leak.
While the kits are cheap, its the time I dont have nor the cash to pay for someone. While I havent made up my mind 100%, I might be selling as a project.
Anyone interested in an 01 with 120k in Nebraska ?
#8096
Gaskets and cleaning
Long story short, mechanic shop did a crap job on my head gaskets 4 years ago, deciding to replace them myself (overheating and leaking). While in the process I've decided to do some cleaning to the existing parts. I have before and after pics of the valve covers and oil pan. I don't have a before pic of the oil pan, but take yours off and thats what mine looked liked. I cleaned using purple power and a nylon brush attachment on my drill. I could have taken the parts to get hot tanked or whatever but I'm pressed with money and this is something I enjoy doing. Besides it's my Disco and I wanted to give it some TLC I neglected to give years ago.
The valve covers are a lot cleaner than they look. Just took the pic at a weird angle.
The_OGCJR (03-27-2021)
DiscoID (03-24-2021)
#8098
#8099
It requires very little in the way of tools to tackle what I'm suggesting. Essentially, a valve spring compressor, some valve grinding compound, a pair of pliers, and some insulation tape. If you've pulled the heads and all of those other parts off, you can do it easily.
There's nothing specific to the Rover engine in regards to this job, so any online guide to replacing valve stem seals and lapping/grinding valve seats will help you.
#8100
