#8741
New headliner
Did my Headliner, as well as sunroof sealing, new roof rails and wiring for cameras and antennas.
Headliner is a bit different, and I wish I would've had a second pair of hands to keep it stretched better. But I like it for now, can always change it later if I get tired of it. I liked the color and pattern, decided to give it a try. It's from Spoonflower, printed on 62" wide, four way stretch material. It's my first time working with fabric, and my old mechanic hands couldn't figure out how to keep all the wrinkles out, but other than that, it went on easy enough.
Cosmos pattern headliner, from Spoonflower. Re-netted the cargo and painted some of the higher up plastics. May go ahead and do the handles and lights later, work in progress kinda thing...
'03 extended roof rails on my '04 D2. For carrying my Kayak
The following 6 users liked this post by Mntnceguy:
ivbyiv (05-25-2022),
Jagman78* (06-16-2022),
Richard Gallant (05-24-2022),
T-rex (05-22-2022),
TimInNova (05-24-2022),
and 1 others liked this post.
#8742
Committed murder X3... (By which I mean, I killed the three amigos ready for MoT test tomorrow!). +1 to whoever it was whom discovered (pun intended) the Autel AL619 works for reading/clearing ABS/HDC codes on the DII, £91 well spent IMO since it's cleared the old wheel sensor code from the Disco & also got into the SRS on our 2000 VW Golf and dealt with a code I'd inadvertently set while repairing under-dash wiring on that.
#8743
#8744
The following 3 users liked this post by TimInNova:
#8745
#8746
Hey andino, don't despair (yet)! I had a similar problem a few years ago. I performed a field repair by cutting back the insulation on the plug wire and "reconstructing" its connection inside the boot. It worked fine for several months at least until I replaced the ignition cables. This many years later I don't recall just what I did and how I did it, but if you're somewhat handy and look carefully at what the situation presents you may be able to figure out a solution. Good luck, and let us know how it goes.
andino (05-25-2022)
#8747
Relatively easy to repair. Use some WD-40 to lube the wire and boot and shove the boot on the wire up about 3". Dig the broken wire out of the metal terminal and spread it a bit at the part where the wire goes in. Strip the insulation back from the core, fold the core back on the wire. Get a piece of stainless wire about 1-1/2" long, shove 3/4" in the center next to the core, fold the other 3/4" back with the core. Crimp the terminal on the wire with the folded back stainless and core. Lube the wire again and slide the boot back down over the terminal.
andino (05-25-2022)
#8749
Got to love when your local garage gets a new tester on the books.... NOT!
Took the Disco for it's MoT earlier, and said new chap (I would've given him a dirty look but he already had a doozy of one) drove it into the test bay, lifted it up & promptly brought it down again and backed it out of the shop. He's refused to test it because the chassis was "too dirty, so I cant tell if there's corrosion"... What an absolute F*$%ing pansy, it's cleaner than last year's test (because it's been out of use for 6 months & I've just got done replacing all the brake lines amongst other stuff under there) & besides if a tester suspects corrosion he's allowed the use of certain tools in order to verify.
Ah well, steam cleaning will be a good opportunity to get some fresh underseal on the more exposed bits... Hang on, will it then be impossible to test because it's too shiny?
#8750
