Old May 28, 2023 | 08:24 PM
  #9281
hasullivan's Avatar
Took my friend on his first trail with his new to him LR3. Trail was a 4, not very hard, and in better shape than it was a few weeks ago.
And we have pictures and video this time. No idea how to post videos though.
The sway bar disconnects worked great and smoothed out the ride. There is a noise that sounds like a spring reseating when articulating, will have to get that looked into, unless any of you know the answer by heart.
Old May 28, 2023 | 09:16 PM
  #9282
tnrangerover's Avatar
Default Major steering upgrades
Finally finished my ball joint and 1-ton GM TRE conversion.
wideopen designs 7075 aluminum alloy links
new ball joints both sides
new used knuckles.
custom built steering dampener bracket. I welded precut tabs from ballistic fab to a steel 1.5” ID dampener mount.
next up:
gas tank skid in a few weeks and sliders later this summer
Old May 29, 2023 | 09:17 AM
  #9283
RA122125's Avatar
Banned
I haven't seen anybody do a GM TRE conversion on the D2, mind sharing more info? I'd be interested in knowing what TRE you used, and what you ordered for your links? Thx!
Old May 29, 2023 | 10:29 AM
  #9284
it’s a permanent change so beware!
I use wide open designs rock hopper 7075 aluminum links. About $300.
32.5” for the drag link and 45.5” for the track Rod. Use LH and RH TRE thread pitch. It’s an option on the drop down menu. It’s required you use antisieze lube when threading the TREs Into the links.
7° reamer. About $100. Be vary careful not to overdrill. Constantly check your angle by inserting the TRE and tightening the nut down. The goal is for the nut to sit flush all the way around. It’s easy to angle it on accident. Use low speed on a hammer drill or a mill if you have one. I drilled until the ream was just right at a full taper all the way down. You want threads to still be inside the knuckle so you can properly tighten it. It’s best to team off the truck as I fubar’d it doing it on the truck. I relaxed with new knuckles I teamed on the bench in a vice. I used a digital angle finder to check perpendicular to the knuckle surface. You’ll have to ream the pitman arm on the truck. That metal is crazy hard, but was easy to hold straight.
GM TREs part numbers ES2234L and ES2234R. $30 each give or take a few bucks. $120ish
you’ll need two of each. Get greasable ones and get the ones that have a sealed boot. Some just have a rubber cap. You’ll need to fill them with grease after install.
These allow you to just undo the nuts and twist the bar to do an alignment.
either get an alignment done or get a tool like the TMR customs alignment tool. Great product. $90ish
shoukd work with stock to up to 5” lift at those lengths. You always want around 1” or more of threads in the links.
you’ll need a 1.5” ID steering Dampner bracket. There are a ton out there. I couldn’t find a double sheet I liked so I just welded one up with parts from ballistic fab and Barnes 4WD.
way heavier duty than anything out there for a disco. Should take the weight of the car just fine.
RTE quoted me $900+ for their smaller SS version, and even with the mistake of needing new knuckles I saved $300 and have significantly stronger components and TREs I can get at any auto parts store in the country
hope that helps!
Old May 29, 2023 | 06:43 PM
  #9285
hasullivan's Avatar
Today I picked up a set of typhoon wheels. Need to go find a 5th. The question is should I leave silver as they are in good enough condition, paint them up like Kalahari wheels, or paint them like kalahari wheels but use giverney green to match the truck? What do you guys think? I like all three.
Old May 30, 2023 | 12:09 AM
  #9286
JUKE179r's Avatar
I now have a dead battery and I still can’t open my bonnet to access it. I had to crawl under her and attach the Ctek MXS 7.0 charger to the starter’s positive connection and to the frame earth for a charge.
So far so good reconditioning the battery. We’ll see what happens tomorrow morning.
Old May 30, 2023 | 06:44 AM
  #9287
The_OGCJR's Avatar
black!
Old May 30, 2023 | 09:41 PM
  #9288
hasullivan's Avatar
Black black or Graphite? I saw another post where a fellow refurbished them and used graphite.
For some reason (Most likly because my marketplace account has no pic no posts and no name) the fellow with 2 of them did not get back.
I found a few sellers on ebay with them so I ordered one. Lets hope the real deal gets to me and they are not trashed.
EDIT: goign to make a thread so as to not clutter this thread.
Old May 30, 2023 | 11:05 PM
  #9289
Bear-Ferr's Avatar
3rd Gear
Default Checking wires, plugs, and injectors today
Old Jun 2, 2023 | 12:41 AM
  #9290
andino's Avatar
Received my Allisport radiator today! Gotta pick up coolant and distilled water and hopefully I can swap it in this tomorrow after work!
