What do these do?
Old Dec 11, 2009 | 03:16 PM
salve7's Avatar
Default What do these do?
I have found these two hoses, conected with a broken T, and I can't find where the missing hose/ part is. I also can't find any pics of it in the rave cd, but that could be because I have no idea where to look. It wasn't with the other stuff in the cooling section. The reason I ask is I just overheated on my way to work and although I am going to try a new thermostat first, I was wondering if this had anything to do with it, and figured I need to find out anyways.
BTW this is for a D1
Thanks,
Jay
Attached Thumbnails What do these do?-wtf_hose1.jpg   What do these do?-wtf_hose2.jpg
Old Dec 11, 2009 | 03:33 PM
Suede's Avatar
Those don't have anything to with your cooling system. They're the reason your cruise control is not working. Those hoses get brittle and break at that T fitting all the time. Replace the T and reconnect the hoses, and there is a good chance your Cruise control will start working again.
Old Dec 11, 2009 | 03:35 PM
tweakrover's Avatar
those are for your cruise control, one goes to the pump under the headlight the other goes through the firewall to the presure release valve on the brake pedal
Old Dec 11, 2009 | 03:53 PM
yesmar's Avatar
^x2 mine are all dry rotted and disconnected also, i don't use my cruise control enough to fix yet.
Old Dec 11, 2009 | 03:56 PM
salve7's Avatar
Thanks that was my second guess as coolant wasn't spewing out of them. I guess that will be covered in either the vacuum portion of the rave or under cruise control.
Old Dec 11, 2009 | 07:06 PM
Yup cruise control.
Old Dec 11, 2009 | 07:53 PM
hilltoppersx's Avatar
yeah you have a vacuum leak in you cruise control
Old Dec 11, 2009 | 10:08 PM
salve7's Avatar
Will that affect anything else?
Old Dec 12, 2009 | 06:52 AM
nothing but your ability to cruise.
Old Dec 12, 2009 | 08:33 AM
XCELLER8's Avatar
and..........don't get too excited because fixing that may not get the cruise working.
VikingDiesel
May 26, 2009 02:43 PM
2k2wranglerx
Jun 19, 2006 05:18 AM
Rope2win
Apr 27, 2006 07:27 PM
Disco.Jay
Feb 20, 2006 08:00 PM
05LandRover
Off Topic
May 4, 2005 01:02 AM
