What is the name of this part?
Old Jun 11, 2015 | 06:23 PM
dgi 07's Avatar
Originally Posted by CRB357
O. Now I just replaced the Purge Valve less than 200 miles ago. I also replaced the Fuel cap. Could the SAI valves being tightened down have possible thrown this code? There is no way the new Purge Valve is bad already.
Unless the purge valve was bad to begin with....
Old Jun 11, 2015 | 06:38 PM
CRB357's Avatar
Well if the new Purge Valve was bad to begin with, then the code wouldn't have cleared itself, right? Bc shortly after it was replaced with a new one, the code went away.
Old Jun 11, 2015 | 07:53 PM
dgi 07's Avatar
Sorry, I missed the where you said it reset itself as opposed to the clearing the code after the repair. Purge flow is fuel tank vapors. SAI is another emissions device , but they should not be related.
Old Jun 11, 2015 | 08:39 PM
CRB357's Avatar
No problem. Just trying to get a handle on what is going on.
My mechanic said he has a smoke machine and we will test it on Monday. See what is happening.
Old Jun 11, 2015 | 10:18 PM
cybercop's Avatar
Originally Posted by abran
Is this a way to test them for real? Which part do you suck on?(that's what she said...)
"Which part do you suck on?"
Did you really ask that question!
Old Jun 12, 2015 | 12:02 AM
abran's Avatar
No, my wife hacked my account
Old Jun 12, 2015 | 09:02 AM
cappedup's Avatar
Exactly. I was also shocked by the grammer.
Everyone knows it should be "on which part did you suck?"
Old Jun 14, 2015 | 04:17 PM
CRB357's Avatar
Can these two valves be cleaned out with brake cleaner?
Old Jun 14, 2015 | 05:06 PM
CRB357's Avatar
Here is a PDF on how to check these SAI valves.
http://download.ms-motor-service.com...083_EN_WEB.pdf
Both of mine have soot on the pump side, which according to that PDF, means they need to be replaced and can not be cleaned up.
Old Jun 17, 2015 | 07:25 PM
CRB357's Avatar
I feel I need to add that the PDF may be misleading after all. Bc both my SAI Valves are functioning properly and are not bad. It was the SAI solenoid that caused the problem. Seems the purge valve and SAI valve have the same connectors fit into each. The are easily confused and plugged into the wrong part. Gray connector goes to SAI Solenoid, while the black one goes to Purge Valve. Reason my SAI valves had soot was bc Solenoid was open causing constant vacuum, which caused valve to stay open all the time, which caused exhaust to backflow, which cause the soot on the inlet port. So, just bc there is soot as the PDF explains, doesn't mean the valves are bad. Pull the vacuum lines off each valve and see if the problem goes away. If it does, then it's the Solenoid. Either it is bad or has the purge valve connector plugged into it.
sforb
Apr 15, 2009 07:41 PM
hag1128
Jan 27, 2009 08:44 PM
ptelhomme
Oct 21, 2008 09:42 AM
jyoung
May 25, 2008 02:11 PM
snorlax
Apr 7, 2008 02:16 PM
