? what part is going bad on my Disco
Old Jan 7, 2012 | 08:06 PM
robgusto's Avatar
Default ? what part is going bad on my Disco
I have a 04 Disco with a strange problem. When I cold start there is a loud squealing noise. The noise is coming from a motor or fan enclosed in a small plastic round case in the engine compartment in front of the pasenger seat. Im guessing ac compressor? The ac and heat works fine so it may be going out or it's not that part. Any ideas, also any ideas on repair cost
Old Jan 7, 2012 | 08:42 PM
Your SAI pump motor is either very dirty or failing and needs to be cleaned or replaced.
Old Jan 7, 2012 | 08:59 PM
robgusto's Avatar
that's it! any ideas on where to get one affordably and how to on how to (step by step) replace?
Old Jan 7, 2012 | 09:15 PM
Here's page from the RAVE, the free factory tech manual set. Whole thing is a download in my signature, you will want this on your PC.
Here is one source. Discovery Secondary Air Injection Pump
Here is new Pump Secondary Air | Land Rover Engine Parts at RoverParts.com
As much as I love salvage yards, a used SAI pump will eventually have the same problem you have now. But if you can get to a u-pull-the-parts junk yard, $25 - $40 for a heater fan (that's what they will think it is) beats $400+ for a new one.
Note: there is a filter inside you can change. And the 04 pump is not the same as an 01, for example.
File Type: pdf
Old Jan 7, 2012 | 09:58 PM
robgusto's Avatar
Great info, I will definitly call some local junkyards to see if they have some discos to save a buck!! If not 175 is not a bad price. I found a site that has a step by step replacement and it looks simple to replace.
Old Jan 7, 2012 | 10:02 PM
The RAVE manual page is not enough? They have a lot more in the manuals.
TATZOO
Jun 10, 2013 05:22 PM
Phototone
Apr 7, 2008 12:01 PM
StevenDiscoII
Feb 20, 2008 03:08 PM
mathis_m1a1
Jan 9, 2007 05:11 PM
dpeek
Sep 4, 2006 11:11 AM
