What is this piece from oil pan?
Old Mar 29, 2016 | 07:59 PM
za105's Avatar
Default What is this piece from oil pan?
I just dropped my oil pan, and as I finally wiggled it out, oil pickup disconnected and removed, I heard a clunk and found this in the pan when I put it on the ground. Where did it come from??
Also aside, I cleaned the nasty oil pan with Simple Green degreaser and it looks great, but as I was cleaning out the inside I noticed a couple tiny metal fragments, one not so tiny, like a millimeter in width. Normal?
Old Mar 29, 2016 | 08:14 PM
LR03NJ's Avatar
Are you suppose to attach an image?
Old Mar 30, 2016 | 09:43 AM
za105's Avatar
Golly, it will not let me upload a photo. Here's a link:
View image: image2
Old Mar 30, 2016 | 09:58 AM
abran's Avatar
View image: image2
That's the spacer towards the back where the pick up tude attached to the main bearing cap. Should be a stud off the bearing cap that that slides over, then the pick up assembly, then a 13mm nut.
BackInA88's Avatar
Item #12 I believe.
Discovery II, Engine, Sump - Rovers North - Classic Land Rover Parts
Old Mar 30, 2016 | 10:42 AM
za105's Avatar
Oh man, that looks just right. Thanks guys!
austinlandroverbill
Feb 17, 2016 02:59 PM
erick846
Dec 1, 2015 11:19 AM
LR4LIFE
Nov 12, 2007 07:23 PM
xstreetz
Sep 21, 2007 12:15 PM
anthonyb
Sep 26, 2006 06:25 PM
