What steering fluid ???
Old Sep 21, 2011 | 07:32 PM
lujac's Avatar
Default What steering fluid ???
What fluid do you use in a 2004 DII?? I searched and found only reference to "power steering fluid". You don't use the same fluid as a DI right??
Old Sep 21, 2011 | 07:37 PM
jafir's Avatar
Most people just use power steering fluid. (that's what it's called.) There is a land rover special fluid, ACE fluid for the trucks that have active cornering enhancement, but it's expensive and not available everywhere.
Old Sep 21, 2011 | 07:39 PM
jafir's Avatar
Old Sep 21, 2011 | 07:46 PM
antichrist's Avatar
Did you look in your owner's manual? It tells you in there.
Old Sep 21, 2011 | 07:50 PM
jafir's Avatar
Didn't texaco get bought out?
"Texaco Cold Climate PSF 14315"
Old Sep 21, 2011 | 09:43 PM
bosshogt's Avatar
I used Royal Purple power steering fluid as it is expensive, but one of the only full synthetics available. On the bottle it states it is good enough for race cars and is full synthetic. Which is required on a DII per the owners manual. No leaks and no whining which is more than I can say for my girlfriend most of the time and she leaks at least once a month
I also did flush the system with the bleeder square bolt directly down on the steering box. I kept flushing till all the old dark fluid was evacuated with a clear hose attached to the bleeder screw. Then let it bleed for another minute. Probably cost me about $39 total, but was well worth it. As I'm guessing at 70,000 miles it was original fluid. I found the best price at PepBoys at $13 per bottle used 3 bottles and bought 4, just in case, and its less than quart quntity containers. If you do it yourself with Royal Purple it still less money than paying any mechanic to bleed and fill the system. And they will over charge you for using full Synthetic, and you really don't know what they are going to use. Less then one hour and your oil pan under the front left tire its any easy DIY.
I use RP gear oil my diffs too and they are oh so quiet and happy. 75w-140
Old Sep 21, 2011 | 10:02 PM
0304Disco's Avatar
I've replaced my power steering fluids with Lucus Power steering fluid in both my Vehicals and have had good success. $7 a bottle and available at just about any auto store.
Athana
Jun 8, 2019 10:23 AM
Rolltop
May 5, 2014 09:17 AM
1998DiscoverySE
Jul 20, 2012 08:02 PM
jycsalas
Apr 17, 2009 02:21 AM
LRScott
Mar 4, 2009 08:39 AM
