What is this warning light?
Old Apr 24, 2013 | 05:45 AM
coors's Avatar
As Savannah mentioned, check the "head connection" located under the console for remnants of spilled soda.
Old Apr 24, 2013 | 07:17 AM
You can also remove the brake fluid level from the possibles by disconnect of switch atop the fluid container.
Old Apr 24, 2013 | 06:58 PM
redwhitekat's Avatar
That's weird your cdl light is red my 04 is yellow
Old Apr 24, 2013 | 07:24 PM
jafir's Avatar
On 99-02 it was considered a "problem" because it wasn't supposed to be left on except for diagnostic use. So the light is red.
In 03-04 they were preparing to bring the feature back for off road use, so they made it yellow.
Old Apr 24, 2013 | 07:26 PM
jafir's Avatar
Originally Posted by rob01189
... im guessing it could be a wiring problem.
Any suggestions?
Being a 51 plate, it's probably a LATE 2001... as the early 2001 would be a Y reg, if I understand correctly.
Do you actually have a CDL in the transfer case? If not, as some later 2001 do not have it, the harness might just be flapping around and could be shorting against something.
cipher982
Nov 9, 2019 11:22 AM
mvjimenez
Jun 12, 2010 10:25 AM
steve c
Jan 26, 2006 09:55 PM
mcclellandm
Aug 9, 2005 05:54 PM
robdis96
Jan 30, 2005 08:45 PM
