What's the best/newest temp monitor?
Old Jan 22, 2025 | 07:05 AM
  #21
Sandgroper's Avatar
Default Temperature monitoring
Originally Posted by Diesel Gypsy
I'm wanting to put a temp monitor guage in my new-to-me Disco 2 and after searching on here it seems like all the posts are rather old and since tech has improved a lot I'm wondering if there are better/ newer/cheaper monitors out there than the Ultra guage everyone talks about.
Please also mention actual model numbers so I can find them! (a search for "ultra guage" with no model # comes up with a bunch of weird scanners that is not helpful)
Hi, I have fitted an Engine Watchdog gauge which measures the temperature of the block or head rather than the coolant. As you would know, one of the weaknesses of measuring the coolant is that if it rapidly departs, the engine can seize before the normal gauge reacts..I've removed the standard D2 pull out cup holder and fitted it along there. You could fit another for the transmission as well if thought necessary. They are an Australian product but our dollar is in the gutter so cost should not be great. Hope this helps...
http://enginewatchdog.com/tm4.html
Old Jan 28, 2025 | 12:25 AM
  #22
AlWorms's Avatar
I fitted the Ozzie "engine guard" for the same reason.
Once the temp sensor isn't covered in coolant, it's a waste of time. Mine is bolted to the top of the engine, directly measuring the head temperature. And set to alarm if it gets too hot too.The secondary sensor is attached to the "cold" side of the radiator to show whether there is additional cooling capacity in the radiator.
Moab63
Nov 29, 2022 11:59 PM
y2kdisco
May 21, 2021 08:44 PM
originalpy
May 4, 2021 09:16 AM
aemnky606
Mar 5, 2018 08:04 PM
Fitzy250
Oct 15, 2011 06:41 AM
