Whats the kit called that lets you lock CDL from inside the truck?
Old Jun 29, 2009 | 05:51 PM
Originally Posted by JBEGIN
So roverland says that a D1 transfer case shifter will not fit a D2, and they had no 2004 shifters in stock.... I'll get the whole deal thru Expedition Exchange...
Wrong, wrong, wrong, no, no, no...yes a DI shifter and linkage from a DI will fit, they may not have any '04 CDL's in stock but why spend $700 for a $300 part if you wait a month or two?
There have been others who have put a DI CDL shifter and linkage into a DII.
Ask DiscoMike, he will confirm this.
Old Jun 29, 2009 | 05:54 PM
I need to add that the only difference between your 1999 DII transfer case and my 1997 DI transfer case is that I have the CDL hooked up from the factory.
Old Jun 29, 2009 | 06:14 PM
JBEGIN's Avatar
10-4 sensai...
Old Jun 29, 2009 | 06:31 PM
Jupiter Rover's Avatar
I'll save you $300!!
http://www.lucky8llc.com/Products.asp?ProductID=2185
Old Jun 29, 2009 | 07:11 PM
RoveringAgain's Avatar
Speaking of CDL kits....
What about the AMV electronic locking setups they use Down Under?
http://www.amv.com.au/SeriesIIDifflock.htm
I get the appeal of having it be just like the factory setup in the '04, but come on it's a pretty simple thing....
Old Jun 29, 2009 | 07:55 PM
I need to clarify this...the only difference in the CDL is that mine came hooked up from the factory and yours did not.
The t-cases are different, not by much, but they are.
Old Jun 29, 2009 | 07:56 PM
I am understanding, Sensai.....
Wax on left hand, wax off right hand, small circle...
Old Jun 30, 2009 | 03:36 AM
JBEGIN's Avatar
Originally Posted by Jupiter Rover
Neat, Pete! I have to ask you if you are the owner of Lucky 8, I always need parts, for instance how much are Magnecor wires, I have them already but want a price for comparison and that wasnt listed when i clicked on the widget for them..... get back to me thanks!
Old Jun 30, 2009 | 09:18 AM
kenk's Avatar
http://www.toddcosuspensions.com/larodilt230d.html
Not sure if its a complete kit, but alot cheaper way to go
Old Jun 30, 2009 | 09:57 AM
Urban Panzer's Avatar
I agree with Pete, This is THE ONE to have, if you would have been prepared to buy the Land Rover Linkage for a D2 from EE (who are WELL overpriced btw) then buy this one..
Its Ashcroft Transmissions "own" version of the D2 linkage setup and they did well to come up with a linkage that is almost the same as the D2a factory one.
A D1 linkage as stated DOES fit, I have added on to my friends '99' TD5, how ever, there is a negative side to the D1 setup, because its a "fixed" linkage and its bolted driectly on the transfer case it transmits more "vibration" / noise into the cabin, not a massive amount and to be honest I could live with it, but its worth mentioning,
You MUST also get a linkage for an Auto FROM an auto and vice versa for a manual as they are mounted differently. You will also have to buy the transmission tunnel "gaiter" and modify it to fit the D2.
