Whats this leaking part…
Old Jan 29, 2023 | 02:22 AM
Rrr_bhb's Avatar
Default Whats this leaking part…
And any idea how to fix it on my 04 disco 2…. Thank you
Old Jan 29, 2023 | 04:25 AM
Gripen's Avatar
Looks like engine oil. Rear main seal? Valve cover gaskets?
As an aside, do you not have O2 sensors?
Old Jan 29, 2023 | 08:57 PM
sqlbullet's Avatar
It's on his list as I recall.
Old Jan 30, 2023 | 12:01 AM
Rrr_bhb's Avatar
Thanks for the replies !! And yes my disconis missing O2 sensors which I plan to install soon. Got them from amazon yesterday and I just pit some penetrating oil on those bolts (were too hard stuck).
on the leaking part, its actually towards the front of the truck, just ahead of the transmission box. It looks loke leaking at the seams. Any idea if I should take it apart( if so will try all easier options first). But just curious at this time if this is something I should be worried about urgently and what are my options
Old Jan 30, 2023 | 03:59 AM
Gripen's Avatar
If the leak is around where the transmission bellhousing mates to the engine block, then I still say either valve cover gaskets or rear main seal. Check the back of the cylinder heads for oil as that's easier than checking for the rear main seal.
MRGMAN
Dec 1, 2022 06:45 AM
Brigh04disco2
Aug 21, 2022 05:07 AM
BlackShama
May 26, 2022 10:20 AM
wdalyinnh
Sep 5, 2019 10:45 PM
IMurray21
Nov 3, 2008 11:59 PM
