what's the problem?
Old Mar 12, 2013 | 11:45 PM
01LandRvrDiscoII's Avatar
8th Gear
Default what's the problem?
hi guys, i have an 01 disco 2 and my dad just spent around $3500 on fixing my car about 5000 miles ago. it now has a loud knocking noise when i drive it. whats the problem with it? my dad thinks it could be a lifter.
Old Mar 13, 2013 | 12:11 AM
MC04DII's Avatar
Could be lifter, rod, trapped woodpecker etc. Need a little more info to help.
Old Mar 13, 2013 | 12:25 AM
8th Gear
well, the work we had done was, new: o rings, head gaskets,water pump, front drive-shaft. all the fluids were changed 2000 miles ago. i don't know if this would help you, but that's all the work we had done to it. also the service engine light is on
Old Mar 13, 2013 | 12:27 AM
jfall's Avatar
You need to take a video of it with your cell phone and post it on youtube.
Then put the link to the video in this thread.
Old Mar 13, 2013 | 12:58 AM
1. Loud knocking when you drive. So don't drive, or damage can be much worse. Loud is a word with many levels of meaning.
2. Knocking when you crank up and just idle? Go away or gets louder if engine speed increased?
3. Take a yard stick or broom handle and hold one end to you ear, and touch other end on valve covers to see if you can hear noise louder on one side of the other (rocker arms).
4. If you unplug spark plug wires one at a time, you may isolate the cylinder involved. The idea is that by removing the pressure from the explosion in the cylinder you drop the noise for a bearing problem.
Old Mar 13, 2013 | 01:47 PM
nychaze's Avatar
Pretty much all of the parts stores (autozone, advance, napa, etc) will read the codes for the check engine light. Report back with the codes they read, don't worry about the description, just get the codes (P###).
Old Mar 13, 2013 | 01:54 PM
jljde's Avatar
The problem appears to be that you have some engine trouble.
That'll be $50 please.
Old Mar 14, 2013 | 11:56 PM
8th Gear
thank you guys for the helpful tips, i appreciate it
Old Mar 15, 2013 | 12:05 AM
Dave03S's Avatar
Thank you for all the details.
Rover Rog
Nov 6, 2013 01:42 PM
Fredzzz
Oct 11, 2013 11:39 AM
XxRoverAllOverxX
Mar 23, 2012 04:49 AM
