When can the manual lock be operated ?
Old Oct 26, 2025 | 01:16 PM
Externet's Avatar
Question When can the manual lock be operated ?
Hello.
The manual lift/push **** on the window sill trough the door panel; when can and cannot be pushed/pulled and accomplishes what ? With engine running, what does pushing it does and can be pulled to undo ?
With engine not running, keyfob not involved, same: can be pushed/pulled to accomplish what ?
Weird question, sorry, but have never used it and never locked my Disco. (paranoia) Truly, I do not know what is it for
Any different behavior if the alarm is set or not ? Can you get yourself 'prisoner' ? What if that other CDL control switch is manually set for all doors ?
Old Nov 15, 2025 | 05:25 PM
Bruce Kissinger's Avatar
3rd Gear
That is a great question and I hope someone can answer it. I also don't lock the doors for the same reason that you mentioned.
Old Nov 16, 2025 | 05:38 PM
Extinct's Avatar
Manual locking mechanism only, you can lock the doors from the inside the door with the door open and then slam it shut except the driver's door.
Rufflyer
Jan 18, 2025 09:27 PM
Hockey_Steve
Jul 4, 2023 03:36 PM
ethan777
Oct 22, 2017 06:16 PM
floundering
Oct 22, 2013 09:00 AM
twoxred
Nov 20, 2012 05:33 AM
