Where did my windshield wiper fluid go??
Old Feb 2, 2015 | 11:45 AM
kfx4001442's Avatar
When mine stopped working it would also leak out immediatley after filling also. My issue was a hose had pulled off a nipple on the bottom of the tank. The tank is easy to get to. About 6 phillips head screws and one 10mm bolt I think is what I had to take out to allow the front driver wheel well plastic to pull back far enough to get in there and inspect/plug hose back up. After that it held fluid and worked fine. Mine has never been in a crash though. Hopefully you dont have a crack in it, or if you do maybe you can seal it up with some epoxy.
Also the little lines that come out of the driver side under the hood and run up the underside of the hood are known to dryrot and crack from all the heat cycles and age. Another easy fix if so.
Old Feb 2, 2015 | 09:28 PM
Disco-2-Guy's Avatar
3rd Gear
Default re: similar problems
Originally Posted by jimvw57
could be the line from the pump was never put back on, or line up by the washer after the tee is split. fluid will run out the easiest way (disconnected hose or cut in hose) instead of going out the washer nozzle onto the windshield.
I will get under the car and check her out soon. Thanks for the insight.
A5scott
Sep 9, 2011 10:35 PM
hilltoppersx
Sep 22, 2010 07:44 PM
SpeedAgent
Oct 10, 2007 09:28 AM
Dublz
Sep 14, 2007 12:36 PM
Oldracer
Dec 25, 2006 04:46 PM
