where to find transmission fluid level check stick
Old Aug 6, 2013 | 12:18 PM
  #21
slabrat's Avatar
Originally Posted by unstable
-Drain the transmission.
-Break loose the fill plug and keep track of both plugs
Good write up I need to do this.
I usually loosen the fill plug first as a rule for Tranny and Diffs. Just in case. I know you are taking the pan off but I still like to loosen the plug first. Mainly because I am paranoid about not getting all the bolts out etc.
Old Aug 6, 2013 | 02:28 PM
  #22
acg's Avatar
acg
Here is a great Youtube video on changing the transmission oil and filter:
Old Aug 6, 2013 | 05:09 PM
  #23
JavaRacer's Avatar
Originally Posted by polar
I used the Valvoline pump.Part# VV818 $8.00 at the local parts store will fit into any Quart bottle I have seen.
Put the vehicle into park,start the vehicle,engage the EM brake,crawl under the vehicle while running in park and the EM on.Remove the upper most plug on the tranny pan,prepare the plug for reinsertition,meaning clean dirt/grit and repalce crush washer if needed,take the VV818 insert it into your favorite Trans fluid quart bottle. pump fluid till a slitedribble occures.remove pump tube, enter cab of vehicle and depress brake peddel.slide shifter leaver from park to First gear,leaving it 10 seconds at each notch/gear.once in first gear repeat steps backwards to park again. leave in park(vehicle still runing. crawl back under the vehicle and pump fluid till a steady stream of fluid comes from fill hole. reinsert the cleaned plug. wipe any fluid from pan(using caution and keeping clear of hot exposed parts) re enter cab and turn engine off. clean up items used.re enter cab and procede on test drive. Task Complete.
Now THAT is a nice write-up! Simple, step-by-step, and specific. Well done!
Rover_Hokie
Apr 21, 2015 08:10 AM
Externet
Sep 20, 2014 07:23 PM
cornbreadj
Feb 24, 2014 08:00 PM
FlyingZebra34
Feb 22, 2014 05:39 PM
GARovee
Aug 22, 2010 09:57 AM
