Who can help me out?
Old Nov 28, 2013 | 08:02 AM
ShaggySE7's Avatar
Default Who can help me out?
Is there someone close to Martinsburg WV 25401 who has a scan tool that they wouldn't mind using to reset my 3 amigos? I took my disco hunting and was doing a little wheeling and my brakes were squeeling a bit from dirt etc. Just want to reset and see what codes I have if possible. I'm probably going to get my own for Christmas. Having them on is just annoying to me. Will disconnecting the battery for a period of time clear them? Any help would be greatly appreciated!
Old Nov 29, 2013 | 12:55 PM
SuperSport's Avatar
Disconnecting battery won't clear them. I also get 3 amigos when my brakes squeal. It throws a code about the left rear sensor out of specs. I can force it to happen if I brake just right. I need to replace the new pads in there because they are cheep, but they are now, so I've been putting it off. I also wonder if adjusting the gap in the sensor would help? I might try that too.
For what it's worth, it drives me CRAZY too when they are on, but it should not cause you any harm. My only concern is when I have my wife drive the truck, can it cause the ABS to not function correctly and put her in peril?
Old Nov 29, 2013 | 04:29 PM
ShaggySE7's Avatar
Well my ABS seems to be working. I guess I'll be living with for a bit. I just hate seeing the lights on!
Old Nov 29, 2013 | 06:37 PM
SuperSport's Avatar
Wish I were closer, I'd be happy to turn them off for you. What about calling around local parts stores and see if they'll read them for you? Many shops will let you read obd, maybe one will have an abs reader...
Old Nov 29, 2013 | 07:51 PM
ShaggySE7's Avatar
I'll check around to see if there are any stores with ABS scanners. I have a scan gauge and I am getting the PO 1590 which is rough road. It will not clear until I clear the ABS codes.
sideshow
Oct 27, 2013 10:11 AM
rover newb
May 12, 2011 05:42 PM
Davis1978
Oct 13, 2010 07:59 PM
palabratic
Dec 5, 2009 07:52 PM
starcraft
Mar 18, 2008 09:42 PM
