Will adding an ‘02 OEM oil cooler to an ‘04 affect oil pressure?
Old Jan 4, 2025 | 02:52 PM
Tony Luna's Avatar
Default Will adding an ‘02 OEM oil cooler to an ‘04 affect oil pressure?
I have a good oil cooler and lines from an ‘02. Will installing this on an ‘04 (LR geniuses omitted oil cooler this MY) negatively affect oil pressure?
Thanks in advance.
Old Jan 4, 2025 | 04:32 PM
jastutte's Avatar
hasn't affected my '04.
Old Jan 4, 2025 | 04:44 PM
The Deputy's Avatar
No it shouldn't.
Old Jan 4, 2025 | 08:06 PM
Tony Luna's Avatar
Thanks for the prompt replies. I vaguely remember reading about lower oil pressure concerns with adding a cooler to ‘04s here on the forum some time ago.
Old Jan 5, 2025 | 04:14 PM
Tony Luna's Avatar
Found the old post I was referring to - https://landroverforums.com/forum/di...e2/#post919896
Response #3 mentions the need for a pressure relief valve in the front cover that may - or may not - be included in ‘04 front covers.
How would I be able to tell if there is a PRV in my cover? New build and new genuine LR front cover from Rimmer Bros - https://landroverforums.com/forum/di...ild%85-124413/
Thanks
Old Jan 8, 2025 | 07:09 PM
Extinct's Avatar
They will be under the two hex headed plugs at the bottom of the front cover if they are there, a piston with a spring behind it and then the cap on top of that
Old Jan 9, 2025 | 09:01 AM
Tony Luna's Avatar
Visible from here?
Traveling at the moment.
Old Jan 9, 2025 | 06:50 PM
Extinct's Avatar
Visible from here?
Nope, there are two plugs held in with snap rings on either side of the front cover (not hex-head, I mis-spoke initially).
Old Jan 9, 2025 | 09:56 PM
Tony Luna's Avatar
Yep - I know what you’re talking about.
neillr
Jul 28, 2019 12:41 AM
metzdmichael
Jul 12, 2018 04:04 PM
Aj6543
Jun 24, 2018 09:56 PM
0304Disco
Apr 27, 2016 08:59 PM
abran
Sep 22, 2014 09:02 AM
