Will crank but not start, constant dead battery, ugh... help please.
Will crank but not start- Solved!
2001 Disco 2 V8
Will crank but not start, parasitic draw (complete battery drain in hours), flashing M and S lights, no signal from crankshaft position sensor to ECU, no spark.
Whats been done/checked: Replaced CPS (twice and correctly), fuses checked, battery checked.
Any ideas?
Solved: Bad ECU.
Was swapped out with an ECU, BCU and a gauge cluster all from the same donor (a 99 Disco 2).
EASY swap/install, 5 minutes with FOB key in ignition on position 2 (to sync), and she fires up.
...AND I had a bad battery (unrelated to ECU).
Tears of joy!
Any ideas?
Solved: Bad ECU.
Tears of joy!
