Will crank but not start, constant dead battery, ugh... help please.
Old Jun 21, 2018 | 11:51 AM
BlackCat's Avatar
4wd High
Exclamation Will crank but not start- Solved!
2001 Disco 2 V8
Will crank but not start, parasitic draw (complete battery drain in hours), flashing M and S lights, no signal from crankshaft position sensor to ECU, no spark.
Whats been done/checked: Replaced CPS (twice and correctly), fuses checked, battery checked.
Any ideas?
Solved: Bad ECU.
Was swapped out with an ECU, BCU and a gauge cluster all from the same donor (a 99 Disco 2).
EASY swap/install, 5 minutes with FOB key in ignition on position 2 (to sync), and she fires up.
...AND I had a bad battery (unrelated to ECU).
Tears of joy!
Old Jun 21, 2018 | 02:08 PM
PalmettoDisco's Avatar
New purchase, never seen it run and trying to fix? Or had it while and just started doing this?
More, or less, things to check, considering engine running history.
Old Jun 21, 2018 | 02:36 PM
The Deputy's Avatar
If you've replaced the CPS twice...and still have no signal...check the entire harness/plug and ECU connection/plug. Make sure battery is fully charged and all terminals are clean and tight, especially ground cable to alternator bracket.
Are there any codes at all?
Brian.
Old Jun 22, 2018 | 05:48 AM
shanechevelle's Avatar
You can pull the fuses one by one and see where your draw is.
Report back.
Old Jun 25, 2018 | 06:05 PM
BlackCat's Avatar
4wd High
Thanks for all the help! ^_^
Saakki
Jan 20, 2017 08:25 AM
Charlie_V
Aug 19, 2015 06:36 PM
lrjon
Dec 18, 2013 02:52 PM
tom_mccallum
Apr 16, 2010 06:39 AM
Thumper 73
Apr 2, 2010 10:40 PM
