Will it move?
Old Feb 10, 2013 | 07:35 PM
sam1234's Avatar
Default Will it move?
With just the rear driveshaft in only?
Old Feb 10, 2013 | 07:36 PM
jafir's Avatar
If you still have a locking transfer case installed, and you crawl under and lock it. If not, then no.
Old Feb 10, 2013 | 07:43 PM
sam1234's Avatar
Great! Scared the hex outta me! How do you shift it, and is it ok to make short runs?
Old Feb 10, 2013 | 07:46 PM
MC04DII's Avatar
With the the CDL engaged you can drive it like normal. It's just like a 2wd. I did this for about a week with no issues.
jafir's Avatar
Oh. You mean will it roll away? If you set the hand brake, it uses the rear driveshaft, so you should be fine. Just putting it in park will not work, unless you've locked the transfer case.
Old Feb 11, 2013 | 10:39 AM
jfall's Avatar
hand brake clamps the transfer case.
As long as you are in CDL lock
it should be OK.
Old Feb 11, 2013 | 10:46 AM
SuperSport's Avatar
That's funny, just this past weekend I learned this. I was on a frame twister portion at a 4x4 OHV park. I had TWO wheels in the air, and TWO wheels on rocks. I set the brake, opened the door, and started out of the truck. Once I let go of the brake, it started to roll forward! Oops, forgot it can still move, even with brake set. It does not set the back brakes like some E-Brakes, but rather sets the driveline leaving the tires on the ground able to transfer the motion to the floating tires.
I just hope I never forget that on a BIG hill some day, as it could get away from you pretty quickly!
nathan214
Oct 21, 2008 06:21 PM
MouseR
Feb 20, 2008 08:14 PM
felipenaves
Nov 5, 2007 06:49 AM
alrd
May 25, 2007 07:18 AM
