window regulator nylon nobs
Old Jan 29, 2019 | 09:45 AM
roverwandeveg's Avatar
4th Gear
Default window regulator nylon ****
Hi anyone know where to get the nylon wear pieces for the channels in the window regulator for disco 2? Saw it once on atlantic british but cant find them now.
Old Jan 29, 2019 | 10:34 AM
mln01's Avatar
For the two-piece, 3D-printed rollers search for "Shapeways" on this forum. According to the person who designed them, cement the two halves together using acetone after they are mounted on the regulator.
Old Jan 29, 2019 | 10:55 AM
4th Gear
Thanks i'll check it out
Old Jan 29, 2019 | 01:26 PM
redrover75's Avatar
Default Hilman
I replaced mine with hillman nylon washers. Cut off the old one and put the correct size in boiling water to soften them up and push them on to the peg. pretty simple, cost about $2 i think. and you can get them same day. there is a thread on it here somewhere.
Old Jan 29, 2019 | 06:43 PM
Extinct's Avatar
I have done both the abovve, the Shapeways are easily worth the few extra bucks for the easy of use. I like to use safety wire to keep them together instead of glue.
GCBurke
Jan 28, 2019 09:01 PM
04duxlr
Mar 3, 2014 02:02 PM
workinghard1713
Jun 21, 2013 01:21 PM
808Disco
Sep 27, 2009 10:23 PM
dcreekmore44
May 7, 2009 02:21 PM
