Wipers come on with high beams!
After being parked for a few months while the engine was rebuilt, my 2004 developed an issue.
-When driving with the low beams on, the wipers come on when either the high beams are turned on or the horn is honked.
-The wipers stay on even if the I turn the high beams off.
-The wipers stay on until I turn the lights either completely off or to the driving light position.
-The wipers run a few more cycles then stop in the park position.
-The rear wiper does the same.
-If the lights are off and I flash the high beams or honk the horn, the wipers do not come on. -
-If I don't use the high beams or the horn, the wipers (and the low beam or driving lights) work properly.
Thoughts?
Thoughts?
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
you are not the first......maybe this will help ....found using forums search:
https://landroverforums.com/forum/di...16/#post499608
I finally made the time to investigate further. The interior fuse box and the stalk switches seemed okay from a cursory look.The next thing I looked for was a grounding issue. The grounding point behind the left headlight was loose! A quick clean and tightening solved the issue. Nice to have a quick, easy and free repair for a change.
The following 2 users liked this post by JohnHZ3:
hasullivan (03-17-2023),
YETIX (03-17-2023)
VikingDiesel
05-17-2009 10:27 PM
