Wipers come on with high beams!
Old Mar 2, 2023 | 05:18 PM
JohnHZ3's Avatar
Default Wipers come on with high beams!
After being parked for a few months while the engine was rebuilt, my 2004 developed an issue.
-When driving with the low beams on, the wipers come on when either the high beams are turned on or the horn is honked.
-The wipers stay on even if the I turn the high beams off.
-The wipers stay on until I turn the lights either completely off or to the driving light position.
-The wipers run a few more cycles then stop in the park position.
-The rear wiper does the same.
-If the lights are off and I flash the high beams or honk the horn, the wipers do not come on. -
-If I don't use the high beams or the horn, the wipers (and the low beam or driving lights) work properly.
Thoughts?
Old Mar 2, 2023 | 06:12 PM
YETIX's Avatar
Your wipers are haunted? Sorry, I have no idea save maybe it has to do with the headlight washers that come on with the wipers (as I understand it).
Old Mar 3, 2023 | 07:42 AM
XRAD's Avatar
you are not the first......maybe this will help ....found using forums search:
https://landroverforums.com/forum/di...16/#post499608
Old Mar 3, 2023 | 03:17 PM
JohnHZ3's Avatar
This will stay in the running for a possible cause until I figure something else out!
Thanks for the reply. I did see this but the problem was a bit different and there was no conclusive resolution. I do intend to look into the stalk switches.
Old Mar 17, 2023 | 02:08 PM
JohnHZ3's Avatar
I finally made the time to investigate further. The interior fuse box and the stalk switches seemed okay from a cursory look.The next thing I looked for was a grounding issue. The grounding point behind the left headlight was loose! A quick clean and tightening solved the issue. Nice to have a quick, easy and free repair for a change.
sblvro
Feb 16, 2023 01:30 PM
Rover Rog
Jan 15, 2015 10:48 AM
kilted
Jun 9, 2013 07:18 PM
superframer
Jul 24, 2009 12:36 PM
VikingDiesel
May 17, 2009 10:27 PM
