XYZ switch
Old Nov 23, 2020 | 01:06 PM
juicyhotsauce's Avatar
Default XYZ switch
I replaced my XYZ switch and I am still having issues. I am thinking that the used replacement part is no good either. My question is do I need to have anything done on the computer to reset the switch or to make it work? or does replacing the switch automatically fix the issue?
I think I may bite the bullet for a new switch. Unless someone has some good ideas..
Thanks in advance for the help!!
Old Nov 23, 2020 | 02:24 PM
JUKE179r's Avatar
do you have any specific fault codes?
Check all the wiring up to the new XYZ switch for chaffing or grounding.
Old Nov 23, 2020 | 02:54 PM
P0705
Old Nov 23, 2020 | 08:26 PM
JUKE179r's Avatar
P0705 = "Gear position switch incorrect outputs" so it's the XYZ switch or the wire loom to it is buggered. Spray some contact Cleaner spray in it's connector plug first then ensure you have the XYZ switch correctly installed per the RAVE manual. Cycle through the selectors and check that a) the LED on the Gearshift lights up for each position and b) the LCD in the instrument pack matches what you've selected.
Also... describe the symptoms you are experiencing. do you have 3 amigos and M+S flashing or what?
Read @mln01 XYZ install and positioning post ...
https://landroverforums.com/forum/di...50/#post491521
D2 Rave Manuals...
https://discoii.wordpress.com/resources/
Old Nov 23, 2020 | 08:33 PM
Best4x4's Avatar
With the XYZ Switch installed, but the 2 bolts loose you can move the XYZ switch forward or backwards. You want the dash indicator, and the gear shift indicator showing the same thing. Try it in either direction and see if the issue is fixed in one position or the other.
Old Nov 24, 2020 | 09:07 AM
I have the M&S flashing.
Old Nov 24, 2020 | 09:48 AM
Best4x4's Avatar
Make absolutely sure your battery terminals are clean & tight. Also make sure the battery is good at 12.5-12.9v.
bcolins
Sep 18, 2023 09:32 AM
Aaron Barnes
Apr 3, 2019 10:34 AM
chaz
Feb 24, 2012 10:13 AM
Fairview
Feb 23, 2011 04:43 AM
njb8199
May 30, 2010 10:26 PM
