Engine & Internal Chat about beefing up your engine's insides here.
Oil Change
Old May 28, 2012 | 04:35 PM
Dbracamontes's Avatar
3rd Gear
Default Oil Change
I just bought a 1991 range rover and the oil need replacing. Do i have to take in to get it done or can i just do it my self like in most vehicles?
Old May 28, 2012 | 07:15 PM
See https://landroverforums.com/forum/di...estions-46975/
Rotella 15W40 is a very good oil to use. Change early and often.
You can download factory manuals called the RAVE at link below.
There will be lots of other things that need greasing or oil changed (differntials, transfer case, transmission, CVs, Wheel Bearings, etc.)
Old May 29, 2012 | 03:41 AM
3rd Gear
alright cool, it should be just like any other oil change i suppose?
Old May 29, 2012 | 03:58 AM
Yes. Here are some pages from the shop manual, note that there are other things to drain and refill, but plan on doing them very soon, just oil change and underside inspection first. Factory drain interval was 7500 miles, but most owners go for 3000 - 5000 instead.
File Type: pdf
Old May 29, 2012 | 09:18 AM
What you need to be more concerned about do is a major service, before you do any major wheeling. Look at the sticky at the top of the D1 section for major services and plan on doing them all or that new to you, old truck is going to have issues.
Paul3221
Nov 25, 2013 12:12 PM
drewski
May 31, 2013 10:50 AM
collin Barrows
Aug 28, 2011 07:13 AM
mwindth
Dec 21, 2010 08:28 AM
tito5590805
Oct 4, 2010 09:11 AM
